swracecars roll cage question
Old Dec 10, 2005 | 04:05 PM
blueintegra90's Avatar
Default swracecars roll cage question
i am about to build a 92 civic hatch and was going to put a cage in it. i've read to put a 10pt in it. my qestion is the swracecars 10pt a legal cage for racing if installed in the car. also would i have to weld and bolt it in or just weld it in. thanks
Old Dec 10, 2005 | 10:19 PM
pgmatt's Avatar
Default Re: swracecars roll cage question (blueintegra90)
Yes and weld it in.
Old Dec 10, 2005 | 10:21 PM
dunkd's Avatar
all cages have to be welded in to be tech legal.
Old Dec 10, 2005 | 11:45 PM
stealthmode62's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">all cages have to be welded in to be tech legal.</TD></TR></TABLE>
The plates can be bolted to the floor, which after welding to my thin floor I would have bolted the plates in if I did it all over again. The thin floor doesn't sit well on my mind, but Tony1 suggested welding the plates to the rockers and I'm going to do that.
Old Dec 11, 2005 | 05:33 AM
Default Re: (stealthmode62)
thanks for the help guys
Old Dec 11, 2005 | 11:47 AM
SPOOLINmatt's Avatar
Default Re: (blueintegra90)
so i can bolt my plates to the floor near my front speakers where the door bar will be welded to? with a black plate under the car?
Old Dec 11, 2005 | 02:31 PM
BoOstedEM1's Avatar
Default Re: (SPOOLINmatt)
Dont the plates have to be a certain dimension also, like 5"x5" or something like that.???
Old Dec 11, 2005 | 09:21 PM
Default Re: (BoOstedEM1)
You can bolt the plates in. The only place where I was comfortable with the welding was in the back next to the shock towers. It's real thick there, but the floor has indentations in it and the plates have to be welded completely around, so even there it may be easier to bolt as well.
The plates have to be 6"x6", and the thickness I believe is 1/8, but don't quote me.
Old Jan 2, 2006 | 07:46 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
how should you bolt them down to make it pass tech? 4 bolts in each 6x6 plate? what size bolts?
Old Jan 2, 2006 | 09:25 PM
2FastxEg's Avatar
you only need 6x6 plates on main cage points such as the main hoop and front of the cage where it connects to the floor under the dash... a common misconception that people have is that the rear kicker bars have to have 6x6 plates too, but that is not the case, the rears can be any size plate, most recommendd would be to have a plate welded on to the strut tower...
Old Jan 3, 2006 | 06:43 AM
Zubaltec's Avatar
Default Re: (2FastxEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FastxEg &raquo;</TD></TR><TR><TD CLASS="quote">you only need 6x6 plates on main cage points such as the main hoop and front of the cage where it connects to the floor under the dash... a common misconception that people have is that the rear kicker bars have to have 6x6 plates too, but that is not the case, the rears can be any size plate, most recommendd would be to have a plate welded on to the strut tower...</TD></TR></TABLE>
I thought the same thing. Till it got inspected. I was told ALL plates have to be measured 6x6. So I guess it's up to the inspector.
Remember these rules are for YOUR saftey and the rest of us on the track.
John
Old Jan 3, 2006 | 11:25 AM
HybridKOOP's Avatar
Default Re: (Zubaltec)
What size wire is everyone using in the MIG for the plates to the floor? I believe it should be .023...
Old Jan 3, 2006 | 05:29 PM
platinum00's Avatar
Default Re: (HybridKOOP)
anyone know how much these cages weigh?
platinum.
Old Jan 5, 2006 | 07:11 PM
Speed Raycer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">What size wire is everyone using in the MIG for the plates to the floor? I believe it should be .023...</TD></TR></TABLE>
Put the gun down...Step away from the welder!
.030 and don't use a 110v unit.
Old Jan 5, 2006 | 08:58 PM
1QwIkEf's Avatar
Default Re: (Speed Raycer)
so if i bolt the plates in will it pass tech? if i do bolt them i how should i do it
blackeg
Apr 13, 2010 04:10 PM
eatmydust223
Welding / Fabrication
Sep 5, 2007 10:26 AM
Hockey27925
Oct 5, 2005 06:45 PM
b18cx
Oct 30, 2003 08:33 PM
275Performance
May 1, 2003 02:43 PM
