05 600RR question
Old Dec 10, 2005 | 03:18 PM
EMphaticONE's Avatar
Default 05 600RR question
will an 02 F4I front wheel and brake fit an 05 600RR?
Old Dec 10, 2005 | 07:15 PM
Default Re: 05 600RR question (EMphaticONE)
anyone? please help.
Old Dec 10, 2005 | 08:40 PM
yimmy's Avatar
Im not exactly sure but I highly doubt it. Post it up on 600rr.net
Old Dec 11, 2005 | 08:08 PM
Default Re: 05 600RR question (yimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yimmy &raquo;</TD></TR><TR><TD CLASS="quote">Im not exactly sure but I highly doubt it. Post it up on 600rr.net</TD></TR></TABLE>
thanks for the website; not having much luck there either.
Old Dec 11, 2005 | 08:12 PM
marmaladedad's Avatar
The 05 600RR employs radial brakes.
All F4i do NOT.
Old Dec 11, 2005 | 08:21 PM
Default Re: (marmaladeboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">The 05 600RR employs radial brakes.
All F4i do NOT.</TD></TR></TABLE>
thanks for the help; does that mean the wheel itself will still work?
Old Dec 11, 2005 | 08:23 PM
Default Re: (EMphaticONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EMphaticONE &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help; does that mean the wheel itself will still work?</TD></TR></TABLE>
Highly unlikely. It would depend on the axle, spacers, and diameter of the rotors.
Can I ask why you need to fit an F4i wheel and brakes to an 05 600RR? Or vice versa?
Old Dec 11, 2005 | 08:27 PM
i laid down my 05 600RR and a friend of mine has an extra 02 F4I wheel; im trying to cut down on repair costs.
Old Dec 11, 2005 | 08:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EMphaticONE &raquo;</TD></TR><TR><TD CLASS="quote">i laid down my 05 600RR and a friend of mine has an extra 02 F4I wheel; im trying to cut down on repair costs.</TD></TR></TABLE>
If you laid it down hard enough to damage the front wheel, be sure to get the forks checked out too.
I would suggest going with the RR wheel. Less changes = less headache.
Old Dec 12, 2005 | 09:08 AM
backlash's Avatar
You will probably end up having to use different axles or spacers. You can always check to see if the part #'s are the same for the wheel.
EDIT: I just checked, looks like they only share a couple of part #'s, the wheel weights and the bolt disk (6x17). The bearings are different sizes also, rotors and everything else are pretty much diff part #'s. If you want to compare the part #'s your self, lookup http://www.ronayers.com
Modified by backlash at 10:21 AM 12/12/2005
Modified by backlash at 10:22 AM 12/12/2005
Old Dec 12, 2005 | 09:21 AM
yimmy's Avatar
Default Re: (backlash)
You can get another wheel for $150 on ebay. I would just do that.
Old Dec 12, 2005 | 09:23 AM
backlash's Avatar
Default Re: (yimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yimmy &raquo;</TD></TR><TR><TD CLASS="quote">You can get another wheel for $150 on ebay. I would just do that. </TD></TR></TABLE>
Just hope it's not bent, that would suck. In most cases you would have to buy the wheel and the rotors seperate too though. Some people sell them together though.
Modified by backlash at 2:33 PM 12/12/2005
Old Dec 12, 2005 | 12:43 PM
Thanks for the help guys.
94turboeg
Aug 22, 2007 03:19 AM
Type X
Honda Civic (2006 - 2015)
10
Feb 3, 2007 12:30 PM
9civichatch3
Jun 10, 2006 06:05 PM
builthatch
Aug 17, 2005 05:37 AM
Aquafina
Jun 18, 2004 10:24 AM
