O2 Sensor Failure/ Check Engine Light
Old Dec 10, 2005 | 03:10 PM
2000Si_b16A2's Avatar
Default O2 Sensor Failure/ Check Engine Light
I drive a 2000 Civic Si... I've been having a problem lately of my car managing to fry my o2 sensor. My check engine light always comes on telling me its toast. Seems to have o2 sensor failure every 2 months after putting in a new one... Its happened twice now and I dont want to have to keep paying a lot of money each time those things go out. I'm running a DC Sports 4 into 1 header with a Greddy mx sport exhaust. Any one ever heard of a problem like this?
Old Dec 10, 2005 | 03:30 PM
sicones's Avatar
Default Re: O2 Sensor Failure/ Check Engine Light (2000Si_b16A2)
what 02 sensor do you keep putting in, if its bosch then thats your answer.
Old Dec 10, 2005 | 03:42 PM
Chiovnidca's Avatar
What trouble code?
Old Dec 10, 2005 | 08:32 PM
Default Re: O2 Sensor Failure/ Check Engine Light (Chiovnidca)
Shop said code was saying the o2 sensor was running slow (failing) it was for the rear 02 sensor
Old Dec 11, 2005 | 04:02 AM
T.J.'s Avatar
Who makes the O2 sensor ? Is it OEM or aftermarket and if so which brand
Old Dec 11, 2005 | 07:01 AM
Lmgrcivic's Avatar
Default Re: O2 Sensor Failure/ Check Engine Light (T.J.)
you could always switch to OBD1 to get rid of that sensor and only have to use the one and leave it in the header
Old Dec 11, 2005 | 07:15 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000Si_b16A2 &raquo;</TD></TR><TR><TD CLASS="quote">Shop said code was saying the o2 sensor was running slow (failing) it was for the rear 02 sensor</TD></TR></TABLE>
Knowing the code may help narrow down the problem. Maybe it doesn't have anything to do with the o2 at all?
Old Dec 11, 2005 | 07:36 AM
JoshuaVTEC's Avatar
I'm in the same boat brother. I have an Apex'i 4-2-1 header, stock cat and midpipe and Mugen Twinloop axleback. I already had to replace the primary (header) O2 sensor, and now a I have a CEL for code 67 ("catalyst system") that I assume probably means the secondary (cat) O2 needs replacing now, but damn those things are expensive
Old Dec 12, 2005 | 10:26 PM
Default Re: O2 Sensor Failure/ Check Engine Light (JoshuaVTEC)
second o2 sensor keeps frying... I keep using the oem sensors
Old Dec 12, 2005 | 10:37 PM
ekb16's Avatar
http://o2simulator.com/
Old Dec 13, 2005 | 01:07 AM
vancoland's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">http://o2simulator.com/</TD></TR></TABLE>
buy the simulator...that code is a bunch of bull crap....most likely when you take your code using the thread at the top of this 92-00 page...its going to come up 67...which is bull because i replaced everything with oem and it still comes up...im starting to think its a scheme to make money offa people
Old Dec 13, 2005 | 03:28 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC &raquo;</TD></TR><TR><TD CLASS="quote"> now a I have a CEL for code 67 ("catalyst system") that I assume probably means the secondary (cat) O2 needs replacing now,</TD></TR></TABLE>
An o2 sensor isn't very likely to fix that.
Old Dec 13, 2005 | 01:45 PM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
An o2 sensor isn't very likely to fix that.</TD></TR></TABLE>
Not really, sounds like you have cat failure. need to hook it up to a real diagnostic computer, like a snappon or something of that sort to find out what exactly it is.
Old Dec 13, 2005 | 05:39 PM
Yeah i was talking to a guy that said it might be that my cat is bad or something... he told me i should buy a high flow cat from cat co. thats 200 bucks tho...
Old Dec 13, 2005 | 05:54 PM
vancoland's Avatar
get under your car and knock your cat with a stick or something...if its rattling...then its bad. I replaced my cat with a high flow and that code still comes up...so its really your call
Old Dec 17, 2005 | 06:13 PM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000Si_b16A2 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i was talking to a guy that said it might be that my cat is bad or something... he told me i should buy a high flow cat from cat co. thats 200 bucks tho... </TD></TR></TABLE>
buying a new after market cat is not a bad idea. But before doing this you really need to find out for sure that your cat is your problem.
HCivicEx2001
Honda Civic (2001 - 2005)
Jul 15, 2019 02:54 PM
etherspeed
Jun 9, 2008 06:06 AM
crxtreme27
Sep 19, 2002 02:01 PM
kapolani
Jul 9, 2002 11:05 AM
89Si
Apr 21, 2002 07:24 PM
