Sedan Swap
Old Dec 10, 2005 | 01:40 PM
candyman206's Avatar
Default Sedan Swap
Alright so I'm looking into getting a 4 door 91. BUt there i not too much info on swaps for these things. I have read info on swaps for Rex's but not for the sedan. I'm not sure if there are difference or anything. But I have read about the difference from a si and dx. You have to convert from dual to multi and such. But what are the specifics between LX's and other sedan models for a swap. Oh yeah I read about a conversion harness, but if I under stand the wiring for a b16 from this https://honda-tech.com/zerothread?id=1193782 tutorial would I still need one? Sorry for the newb questions I am just doing my research for my first attempt. Hope you guys understand and wish me luck.
Old Dec 10, 2005 | 02:03 PM
31flavorscivic's Avatar
Default Re: Sedan Swap (candyman206)
Sedans and hatches and crxs from 88-91 are mechanically identical.
Old Dec 10, 2005 | 02:04 PM
Hamstr323's Avatar
sedan swap is same as rex
also lx would be the same as dx as far as the injection is concerned
Old Dec 10, 2005 | 02:14 PM
Default Re: Sedan Swap (Hamstr323)
So which model would I want if I didn't want to mess with the injection wiring?
Old Dec 10, 2005 | 02:18 PM
Hamstr323's Avatar
88&89 did not come in the ex only 90-91 did for the sedan
ex would not need a conversion harness the only thing that would have to be hooked up is the vtec
Old Dec 11, 2005 | 11:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 &raquo;</TD></TR><TR><TD CLASS="quote">88&89 did not come in the ex only 90-91 did for the sedan
ex would not need a conversion harness the only thing that would have to be hooked up is the vtec</TD></TR></TABLE>
Yup. The EXs are MPFI, same engine and all as the SI.
Someone answer me this. Am I still correct that he needs to convert to either obd-1 or obd-2??
Old Dec 11, 2005 | 11:30 AM
crxnj's Avatar
Default Re: Sedan Swap (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">
Someone answer me this. Am I still correct that he needs to convert to either obd-1 or obd-2?? </TD></TR></TABLE>
Depends what motor swap he gets..He could get the pre obd sir1 b16a swap..
Old Dec 11, 2005 | 11:36 AM
crx2nr822's Avatar
Default Re: Sedan Swap (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
YUP, cause he can still get the OBD-0 b16 swap and not have to do any type of conversion besides adding the vtec subharness
Canadian_EF
Jul 11, 2009 01:14 PM
mrEFman
10
Jan 20, 2007 06:01 PM
killaflex
Apr 17, 2006 01:12 PM
bootsz420
Oct 9, 2005 11:56 PM
