TSX Throttlebody on D16z6
iight I did a search and couldn't find anything about this, so heres my question...would a TSX throttle body fit onto my D16z6 Intake Manifold, if not what will exactly? and also I'm thinking about getting a skunk2 Intake Manifold, would the TSX throttle body fit on that???...thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackDeLSoL »</TD></TR><TR><TD CLASS="quote">iight I did a search and couldn't find anything about this, so heres my question...would a TSX throttle body fit onto my D16z6 Intake Manifold, if not what will exactly? and also I'm thinking about getting a skunk2 Intake Manifold, would the TSX throttle body fit on that???...thanks</TD></TR></TABLE>
I could be wrong, but I would think there is little to no way this would work correctly..
i dont know about the tsx thing, but i would see no way how it could. But a b18a tb will fit on to a d series, go look at ebay and see if you can find one. i believe it is the biggest tb that fits thats oem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97spooncivic »</TD></TR><TR><TD CLASS="quote">i dont know about the tsx thing, but i would see no way how it could. But a b18a tb will fit on to a d series, go look at ebay and see if you can find one. i believe it is the biggest tb that fits thats oem</TD></TR></TABLE>
No how does this make any sense to you? If you know that a B18N TB fits, then you should know that ANY B series would fit. Now it seems common knowledge tha ta B18B throttle body is certainly NOT the largest of the B series throttle bodies... so why would you assume its the largest that would fir on a D?
Also, simply bolting on a larger TB won't help a whole lot since the manifold opening is also rediculously small. You would need either an aftermarket manifold or to open up the mouth of the stock one to see the full potential.
danmej1
Oct 11, 2009 09:41 AM
EG-SIXV-TEC
Oct 10, 2009 09:49 AM
jdmstockeg6
Sep 10, 2007 08:05 AM
px_R
May 2, 2006 07:24 AM
