H-SERIES INTO A 96 BUBBLE
WHATS UP GUYS..
I HAVE A 96 BUBBLE WITH A H-SERIES MOTOR NOT INSTALLED ALSO MISSING A FEW PARTS..I WOULD LIKE TO KNO IF ANY KNOWS A MECHANIC OR ANY ONE WHO CAN INSTALL MOTORS..AROUND THE NORTHERN NJ AREA...THANX IN ADVANCE
Sir, this is Honda tech. Don't speak in all caps, what the expletive is a bubble, and this is not the place to request hybrid work shops.
You can search the member's list - in the upper right hand corner - by city. Find the top three post-count people and shoot them PMs to see if they can tell you what you need to know.
And yes, Caps Lock makes you look like a moron.
I installed one into my friends civic. put an obd1 h22a into a 96 hatch. You need the mount kit and you need the conversion from hydro to cable. Also make sure you buy the cross bar. Pretty much except for converting to cable its the exact same as a changing your d-series to a b-series.
to the 1st four comments...you could have just given me an answer instead of getting smart...
thank u copperfox, archidictus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsmith »</TD></TR><TR><TD CLASS="quote">I installed one into my friends civic. put an obd1 h22a into a 96 hatch. You need the mount kit and you need the conversion from hydro to cable. Also make sure you buy the cross bar. Pretty much except for converting to cable its the exact same as a changing your d-series to a b-series. </TD></TR></TABLE>
the car already ran with the h22 in it..it just needed to be fixed..i had to buy the parts for it
Rever21
May 3, 2017 01:49 PM
