DOHC ZC ??????????
First, what kind of car is it now? Is it an Si? If so, you can use the stock PM6. If not, you need to wire it to MPFI.
And yes, you can use your D-series axles and tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot »</TD></TR><TR><TD CLASS="quote">if you use the same tranny, you would use the same axles..</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex voto »</TD></TR><TR><TD CLASS="quote">If so, you can use the stock PM6. </TD></TR></TABLE>
Why would you want to do that? The ZC would be much better with a PM7.
you can use your axles the only way you would need to change them is if you had a
ZC tranny
"The ZC trans. requires you to use ZC or 90-91 Integra axles, and a ZC intermediate shaft. Because these axles are equal length also
Also, when using the ZC transmission in CRX HF or Civic STD, you will need to swap knuckles/hubs for ones from Si or DX."
if you want to look up more stuff about it
here is a link that will help you out
http://www.thezcr.com/forums/showthread.php?t=7334
gl
ZC tranny
gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_338 »</TD></TR><TR><TD CLASS="quote">you can use your axles the only way you would need to change them is if you had a
ZC tranny
gl
Good info from someone with 8 posts.
ZC tranny
gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote">
Why would you want to do that? The ZC would be much better with a PM7.</TD></TR></TABLE>
Because they're hard as hell to find. If someone sold a pm7, I would have bought it. Now I am in the process of searching classifieds and ebay for a 90-91 pm6 to chip. Way better way to go IMO.
PM6 ('90-91 CRX Si) - This era of CRX ECUs have more aggressive fuel and timing curves than that of the previous years.
sounds like the PM6 will do just fine
if you can check a junk yard on certain days when they bring in a new shipment of cars
you might get lucky!!!!!
GL
GL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic »</TD></TR><TR><TD CLASS="quote">
Because they're hard as hell to find. If someone sold a pm7, I would have bought it. Now I am in the process of searching classifieds and ebay for a 90-91 pm6 to chip. Way better way to go IMO.</TD></TR></TABLE>
hmotors? I have never personally tried to buy a pm7, so I have no idea how hard they are to get a hold of.
Another option would be to find a 90-91 pm6 and chip it with pm7 maps. Also, since the DOHC zc is great for boost, and if you do decide to go boost later on, you can always change the fuel maps on the chip instead of the stock pm7 ones.
I have a spare one sitting around. In fact, I have TWO spares... I was going to give one of mine away when the car sells. My EX is running on a chipped PM6 now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex voto »</TD></TR><TR><TD CLASS="quote">First, what kind of car is it now? Is it an Si? If so, you can use the stock PM6. If not, you need to wire it to MPFI.
And yes, you can use your D-series axles and tranny. </TD></TR></TABLE>
Just a quick observation. Hf's are mpfi to, atleast i know 89-91 is. I'm pretty sure the 88's are, but not 100%.
There's also issues with running a stock pm7 on a regular ZC swap. If I remember correctly there is a couple of sensors that you won't be running that the pm7 will be looking for...one being an exhaust temp sensor and could cause issues with the cold/hot maps.
Run a pm6 with pm7 maps. I'm currently running a pm6 without maps and its fine for something to work for a while...but not anywhere near what the zc wants. I will be converting it to obd-1 in a couple of days instead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote">hmotors? I have never personally tried to buy a pm7, so I have no idea how hard they are to get a hold of.
At the time of my swap they were backordered 3 months on the pm7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex voto »</TD></TR><TR><TD CLASS="quote">I have a spare one sitting around. In fact, I have TWO spares... I was going to give one of mine away when the car sells. My EX is running on a chipped PM6 now. </TD></TR></TABLE>
You have PM.
You have PM.
i have a jdm ef7 and it has no egt sensor , in fact no ef7 i have ever owned or seen has had an egt sensor. Ive never had a problem finding a pm7 ecu over here in new zealand they sell for $40 nz or about $20 us , i have 5 of them in my garage two of them have so called mugen maps in them and they work really well on a zc with IHE
If you can't find a PM7 you can get any 90-91 PM6 and send it out to be chipped with the PM7 program.
Try http://hyperducktuning.com or http://locashracing.com/
Or try a Pg7...it made the same #'s on the dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx »</TD></TR><TR><TD CLASS="quote">
Wow man, those mugs are expensive, you can get a chipped pm6 with custom basemap for 100 shipped, then you'll be ready to tune also, which would be the best route for least money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">Wow man, those mugs are expensive, you can get a chipped pm6 with custom basemap for 100 shipped, then you'll be ready to tune also, which would be the best route for least money.</TD></TR></TABLE>
Or you
Or you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZC CivicJdm »</TD></TR><TR><TD CLASS="quote">DOES ANYONE KNO WHERE I CAN FIND A INTERMEDIATE SHAFT AT FOR A JDM DOHC ZC MOTOR (HYDRAULIC TRANNY)</TD></TR></TABLE>
LOUUUUUUUUUUUUUUUUUUUUUUUUUUUUUD NOIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIISES!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!111one
