Suspension & Brakes Theory, alignment, spring rates....
Keep the Ground Controls or go with Tein s-techs??
Old Dec 10, 2005 | 07:55 AM
undertheradar's Avatar
Default Keep the Ground Controls or go with Tein s-techs??
I've been running GC sleeves for 2 years on stock shocks. Needless to say it was time to change. I ordered some KYB AGX's for a really good price, but after doing some research here, it seems most thing the AGX perform better with springs than coilovers.
The drop would be about the same...as I'm about 2" now, but want to raise it a bit anyways. My dilema is whether or not to give up the adjustability of keeping the raked stance (a tad bit lower in the front) if the Teins don't offer me that.
Any advice? Will the spring shock combo perform a lot better for my daily driving commute?
Thanks!
Old Dec 10, 2005 | 08:33 AM
ED7's Avatar
ED7
Default Re: Keep the Ground Controls or go with Tein s-techs?? (undertheradar)
It will most likely be smoother for daily driving with the teins. I would just keep the ground controls.
Old Dec 10, 2005 | 03:17 PM
EK k kay's Avatar
Default Re: Keep the Ground Controls or go with Tein s-techs?? (ED7)
Get some H&R Sport springs. The front will be a tad bit lower than the rear if that's what you wanted(couldn't tell if you wanted that kind of stance or not). I have a set that I might be selling off my 99 Civic.
Old Dec 10, 2005 | 04:19 PM
DB1_559's Avatar
the tein will def raise ur car a bit for a civic its like 1.7-1.8
Old Dec 10, 2005 | 07:37 PM
Tyson's Avatar
just order a softer spring for the ground controls. youll be able to make it as soft as you want, or whatever.
search through this thread, buy and sell any spring available for much cheaper than new. used eibachs are just as good new, theyre pretty indestructible.
https://honda-tech.com/zerothread?id=553330
Old Dec 11, 2005 | 07:39 AM
m00nr0ck Si's Avatar
Default Re: Keep the Ground Controls or go with Tein s-techs?? (Tyson)
I have s-techs and have no complaints on the ride , there just not low enough IMO.
I would def. hold on to the GC/AGX setup!!!
Old Dec 11, 2005 | 07:06 PM
Sumslapper's Avatar
Year 3030
Default Re: Keep the Ground Controls or go with Tein s-techs?? (dorkoftheyear)
i have had both tein s-techs and ground control on tokico illumina shocks. I had ground controls on, changed to teins, an then back to ground control. The teins definately ride nice and you dont have that rattle or as many squeeks with the springs. I had them on my 00 civic si and it said they lowered 1.9 front and 1.7 rear. it was more like 2.2 front and 1.9 rear when i put them on. Make sure to cut your bumpstops though. I didnt and after riding on them for a few miles, i kept hitting the bumpstops resulting in loud bangs over each dip or bump. I went back to GC because once i put the teins on, i knew that that was the height i was stuck with and they were a little too soft IMO. Definately suited for the daily driver in mind or someone looking for a good ride quality. I like my car dumped to the ground and stiffer springs so thats why i went back to GC. WHAt you should really do is just get a true coil-over setup. Like the Tein SS if you like tein.
Old Dec 12, 2005 | 08:16 AM
alwaysoverkill's Avatar
Tein S tech have very soft rates, almost stock GSR type rates, if anything, i'd go H&R Sport. lowers EK 1.75/1.5 and the rates are 330/280 but progressive. S-tech rates 235/140. To me, S-tech couldn't possibly offer the increased performance a somewhat stiffer spring could, H&R Sports felt soft to me even so S-tech would be like stock to me
Old Dec 13, 2005 | 09:14 AM
SlowIntegra's Avatar
go with the TEIN S-tech
I had them on three of my integras BEST for dialy driver n the ride is great on them.
Old Dec 14, 2005 | 01:02 PM
bmoua's Avatar
i have the GC setup with kyb adj on my EJ8....man...rides really good...have it set to 1 all around....rides great...10x better than my omni full coils 6way adj...tell you that much..bro..good luck with your suspension
Old Dec 15, 2005 | 07:51 PM
kabaroo's Avatar
Default Re: (bmoua)
I have a buddy with kyb's and GC's on is EK. It rides really nice, but does have sway bars also. Thats all i can really add.
Old Dec 16, 2005 | 10:01 PM
Default Re: (kabaroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo &raquo;</TD></TR><TR><TD CLASS="quote">I have a buddy with kyb's and GC's on is EK. It rides really nice, but does have sway bars also. Thats all i can really add.</TD></TR></TABLE>
I have a Progress rear sway...so I'm looking forward to testing out the AGX's.
DC2_2
Oct 14, 2006 06:28 AM
petergriffen
Jun 6, 2006 01:05 PM
sohcvtec97
Feb 25, 2005 07:07 AM
Tad
38
Dec 12, 2003 09:07 AM
far
Dec 5, 2001 04:06 AM
