suspension??
Old Mar 15, 2002 | 09:18 AM
GokuSSJ4's Avatar
Default suspension??
does it affect on the rear if you turn 180 degrees the coil overs in any way . there Teins on a ek hb . the fact that is being doen is to install a braket for a sway bar and it need to go on the botton where you bolt in the chock from the coil over . sway bar is ST
Old Mar 15, 2002 | 10:28 AM
fsp31's Avatar
Default Re: suspension?? (Spoon1)
No effect at all. I've had an ST rear bar installed now for almost 2 years with no trouble whatsoever with either the bar or the installation method.
Old Mar 18, 2002 | 03:07 PM
pornstarSR's Avatar
yes i have the suspension techincs bar on for awhile and i had to do the same thig, no bad effects.....but i changed out to the suspension technics speedtech rear bar and brace.....that one you dont have to spin the shocks....because it bolts the the control arm
zippo1130
15
Jan 15, 2008 07:45 PM
JAYBOOGIEZZ
May 10, 2007 10:29 AM
ek4d00r
Suspension & Brakes
Apr 23, 2005 07:33 PM
