power steering leak 5th gen!!! help!!
Old Dec 10, 2005 | 06:39 AM
DeDonDeRosa's Avatar
Default power steering leak 5th gen!!! help!!
ok i noticed that my pwr steering pump is leaking and dripping behind the alternator onto the block then on the oil pan then to the ground.... but my power steering fluid isnt low when the car is off. and i know its not oil cause i check my oil and its never low so..... why is this ??
Old Dec 10, 2005 | 06:45 AM
mgags7's Avatar
if your ps pump leaks then it leaks...i dont know what else to say....the fluid is coming from somewhere....
it could be oil leaking from the valve cover gasket...the only thing i think would leak on the ps pump is either the o ring on the high pressure line or if your low pressure line isnt fitted on right....
Old Dec 10, 2005 | 06:54 AM
britishlude's Avatar
Default Re: power steering leak 5th gen!!! help!! (DeDonDeRosa)
Are you sure it's not just condensation from your A/C condenser, thought that was in that region ?
If none of your oil / ps fluid is getting lower then it must be the above or a slight coolant loss, failing all else try get a sample of the fluid for a closer look to determine what it actually is.
Old Dec 10, 2005 | 06:59 AM
Default Re: (mgags7)
well the front of the valve cover isnt leaking but the pump it self is leaking cause im guessing that its dripping down the front of the block and puddling up by oil dip stick
Old Dec 10, 2005 | 07:02 AM
Default Re: (DeDonDeRosa)
Most likely the O ring no. 17 on this diagram needs replacing ? While your at it best replace all O rings 18 & 19 as well.
http://www.hondaautomotivepart...+PUMP
Modified by britishlude at 4:18 PM 12/10/2005
Old Dec 10, 2005 | 07:06 AM
Default Re: (britishlude)
is there any way to tell the diff between oil on the ground and PS fluid?
and besides wouldnt the power steering pump leak more when the car is driving cause there is more of a load on it ??? and wouldnt leak as much when its just idleing
Old Dec 10, 2005 | 07:13 AM
Gen2Integra23's Avatar
i had the same problem a couple of weeks ago
i just got all the o-ring and rebuilt my PS pump and no more leak
Old Dec 10, 2005 | 07:19 AM
You could read this it tells you briefly how to identify the different fluids :
http://www.grubbsauto.com/technotes/spots.html
Old Dec 10, 2005 | 08:34 AM
is there a possiblity that its leaking from the ac compressor??? does that ever happen?
Old Dec 10, 2005 | 10:12 AM
Old Dec 10, 2005 | 10:25 AM
When I mention it may be condensation from the A/C I meant that it could be just water forming, this is normal for water drops to be formed through the use of the A/C, it won't be a leak of fluids from the inside as that is refrigerant and would just evaporate without being noticed. Sounds 90% like a small drop of p/s fluid is getting past your O ring.
dilas
Feb 29, 2016 04:48 PM
greenquark
Sep 8, 2014 07:53 AM
faSHOwidIT
14
May 5, 2006 02:16 PM
PaChiLa Leader
Jun 5, 2004 11:06 AM
SIK IN DA HED
Feb 17, 2004 04:52 AM
