del Sol Mounts
Old Dec 10, 2005 | 12:09 AM
del Slo SiR's Avatar
Default del Sol Mounts
Whats up i Got a 2ng gen B16 in a del sol and I was wondering if the DC bodystyle Integra motor mounts will work for me and if so from 95 to wat year???
Old Dec 10, 2005 | 06:25 AM
CRXified's Avatar
Default Re: del Sol Mounts (delSolSiR626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSolSiR626 &raquo;</TD></TR><TR><TD CLASS="quote">Whats up i Got a 2ng gen B16 in a del sol and I was wondering if the DC bodystyle Integra motor mounts will work for me and if so from 95 to wat year???</TD></TR></TABLE>
ur stock mounts will work all u need is the rear bracket on the motor
Old Dec 10, 2005 | 07:37 AM
dohcVTECeg2's Avatar
Default Re: del Sol Mounts (CRXified)
all integra mounnts will bolt directly to your sol
Old Dec 10, 2005 | 08:51 AM
CRXified's Avatar
Default Re: del Sol Mounts (dohcVTECeg2)
when i swapped my JDM b16 into my EG we used all stock mounts because the drivers mount from the teg was different and wouldnt work. i used all my stock d series mounts except maybe the tranny mount which came with my swap and the rear bracket
Old Dec 10, 2005 | 09:03 AM
Del Sol SiR's Avatar
easiest thing to do is use the 94-97 Del Sol VTEC (dohc 1.6L) mounts.
Old Dec 10, 2005 | 10:12 AM
CRXified's Avatar
Default Re: (Del Sol SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol SiR &raquo;</TD></TR><TR><TD CLASS="quote">easiest thing to do is use the 94-97 Del Sol VTEC (dohc 1.6L) mounts.</TD></TR></TABLE>
thats not that easy considering he can use the mounts he has on his car now without changing a thing... the swap will come with the bracket and tranny mount if u ask for it
Old Dec 10, 2005 | 06:22 PM
Default Re: (CRXified)
Thanks but the motor is already in its just that the driver side and the rear mounts are gone, so i was wodering what i can repalce them with and im going to get some energy suspension inserts... I dont got alot of cahs to get polyeurathanes at the moment so the temp route is stocks with inserts not the best but will have to do for now
Old Dec 11, 2005 | 05:37 PM
CRXified's Avatar
Default Re: (delSolSiR626)
i used my stock mounts with no inserts, they werent torn or anything tho, they worked fine for me, no wheel hop or anything when i launched at like 4k
Old Dec 11, 2005 | 10:45 PM
Yeah mine lsted me about a year launching at like 5000/5500
Old Dec 12, 2005 | 10:16 AM
CRXified's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSolSiR626 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah mine lsted me about a year launching at like 5000/5500</TD></TR></TABLE>
i only launched once to do a test run, worked well and was surpised there was no wheel hop on the stock mounts
Old Dec 12, 2005 | 10:28 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSolSiR626 &raquo;</TD></TR><TR><TD CLASS="quote">I dont got alot of cahs to get polyeurathanes at the moment so the temp route is stocks with inserts not the best but will have to do for now </TD></TR></TABLE>
stock mounts with es inserts will perform every bit as well as billet aftermarket mounts unless you are making serious power.
DELshaneSOL
Mar 12, 2012 11:33 PM
hotimportcrx
Nov 27, 2005 09:32 PM
autosport7
Apr 29, 2005 06:58 PM
ShortbusEK
May 4, 2002 01:21 AM
