52mm TWM on B18 ,too big ??
Old Dec 9, 2005 | 05:51 PM
carboy_honda's Avatar
Default 52mm TWM on B18 ,too big ??
Hello everyone , i ordered a 50mm but the stupid shop sent me a 52mm. Now i live faraway from the US so sending the stuff back is not a wise move, im thinking of putting on the 52mm. This is for a circuit racing engines. B18c5 Specs are as follow :
1) 13.2 cr with Wiseco pistons and Eagle H beam rod
2) JUN 4 cams with all JUN valvetrain
3) DC titanium race header
4) Motec m4 pro
5) Custom straight cut close ratio gearbox
6) RC 370cc injectors (85% duty cycle)
7) PNP head
So what happens if a put the 52mm on the engine ? Powerband wise ? I dont want the peak power to higher than 8500 rpm if possible. Please share with me for those who have experince . And also i ordered the 440cc injectors which the seller didnt send , 440cc will it be enough with the TWM ?THX a lot
Old Dec 9, 2005 | 06:06 PM
cptengineer's Avatar
Default Re: 52mm TWM on B18 ,too big ?? (carboy_honda)
engine size?
Old Dec 9, 2005 | 07:19 PM
1.8 oversize 0,5.......
Old Dec 10, 2005 | 08:11 PM
bump ,need info plz
Old Dec 10, 2005 | 08:23 PM
marcin's Avatar
Default Re: (carboy_honda)
http://www.jenvey.co.uk/~Tech_QA.htm
thats jenveys sizing guide.
m.
Old Dec 11, 2005 | 01:18 AM
jt-sport's Avatar
on those jenvey website, you should run 48mm wich is suitable for your 276hp motor
Old Dec 12, 2005 | 05:59 PM
bump for more info
Old Dec 12, 2005 | 08:52 PM
Tbone's Avatar
I think they will be way too big.
I run 48mm's on my motor and it put down 268 whp actual on the dyno.. 255 correcetd sae..
Mine is a big bore gsr/itr setup 85mmbore 87,2 stroke..
Old Dec 13, 2005 | 06:27 PM
So u think i should change the 52 to a 50 ?Sending the stuff back will be expensive and i dont want to deal with the company again. What brand are u running ?
Old Dec 13, 2005 | 07:01 PM
Tbone's Avatar
I run Jenveys.. Try to sell yours locally firts then get new one's.
Old Dec 13, 2005 | 07:31 PM
Real_E-AT's Avatar
Default Re: 52mm TWM on B18 ,too big ?? (Tbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">I think they will be way too big.
Mine is a big bore gsr/itr setup 85mmbore 87,2 stroke..</TD></TR></TABLE>It's 48mm at the plate isn't it?
Old Dec 14, 2005 | 06:28 PM
No one here wants to buy the TWM, what if i put a plenum and filter ? or make a restrictor just like F3 engines. Oh well i will just put it on and dyno it and see what happen , i already bought it anyways....
Old Dec 15, 2005 | 03:27 AM
jt-sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carboy_honda &raquo;</TD></TR><TR><TD CLASS="quote">No one here wants to buy the TWM, what if i put a plenum and filter ? or make a restrictor just like F3 engines. Oh well i will just put it on and dyno it and see what happen , i already bought it anyways....</TD></TR></TABLE>
i think plenum or air filter was not a choice for compensating the throtle size, because throtle size was effecting the runner crossection area that determine the air speed to create torque at certain rpm/powerband, and plenum was not the part of runner crossection area, the area outside the TWM velocity stacks was the second degree of freedom in the IR system.
btw good luck with the dyno, hope you will gain much whp with your ITB
nengx07
Jun 1, 2010 08:49 AM
boostd ls
Sep 8, 2007 12:28 PM
pearlteg
18
Mar 14, 2007 09:51 PM
Baodalazi
Nov 1, 2006 11:22 AM
ultradx
Nov 3, 2005 03:03 AM
