Tranny fill up?
Old Dec 9, 2005 | 01:54 PM
nk2k2's Avatar
Default Tranny fill up?
Hey guys,
ive seen many threads about how people fill their trannys from the VSS...i was wondering do EFs have VSS, if so were is it located, if not then whats the easiest place to fill it at?
Pics would be great!!
Thanks
Old Dec 9, 2005 | 02:49 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Tranny fill up? (4g4d)
Proper fill and drain location:
VSS location:
Alternative places to fill:
Old Dec 9, 2005 | 03:07 PM
Crx Jimmy's Avatar
Default Re: Tranny fill up? (88DXCRX)
Old Dec 9, 2005 | 03:23 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">
Hmmm..
Didn't know that. I'll have to use the plug on the top of the tranny next time. I used to fill my hydro tranny from the VSS but with my cable I have been filling from the proper fill hole, which is a pain in the *** because of it's location and verticle position.
Old Dec 9, 2005 | 04:18 PM
90civSi's Avatar
Default Re: Tranny fill up? (EJ1 wilcox)
how much tranny fluid do you put in??
Old Dec 9, 2005 | 04:22 PM
eda6's Avatar
Default Re: Tranny fill up? (90civSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civSi &raquo;</TD></TR><TR><TD CLASS="quote">how much tranny fluid do you put in??</TD></TR></TABLE>
with the car on a level surface, add fluid until it runs out of the fill hole.
Old Dec 9, 2005 | 05:01 PM
Cuda70's Avatar
Default Re: Tranny fill up? (eda6)
You can buy a $4.00 hand pump at Autozone that screws on top of the tranny fuid bottle and has a hose that you put in the filler hole. Fill it until the fluid is level ith the bottom of the hole and you got it...
Old Dec 9, 2005 | 09:50 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
with the car on a level surface, add fluid until it runs out of the fill hole.</TD></TR></TABLE>
2litres.
Old Dec 10, 2005 | 05:38 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Tranny fill up? (HamiltonRex)
I used to use the breather hole on top of the tranny. Is suppose to have a little black covering over it. Its have the diameter of a pen, though so its takes a while.
jason DB8
Aug 28, 2007 11:01 PM
austincrx
Apr 4, 2007 07:06 AM
twotonecivic
Jan 9, 2007 09:55 AM
ATYPR
May 21, 2002 01:26 PM
