valves ticking very bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech »</TD></TR><TR><TD CLASS="quote">after installing the sk2 st2 cams....valves ticking very bad.... if needs to be adjust..wat should i adjust the intake and exhaust to?? </TD></TR></TABLE>
"iF" is where your problem is lol
I have the same problem with my sk2 stage 2s. I did the valve adjustment at 7in 9exh. I tried 7,8 but the engine was suffocating. I am assuming that the cams eventually wore down the lmas cause the tapping is mostly heard at idle and low rpms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx »</TD></TR><TR><TD CLASS="quote">Hey Rocket.....advice on valve lash for S2S3's?</TD></TR></TABLE>
7/9
7/9
