JDM gauge cluster problem. HELP!!!
Old Dec 9, 2005 | 11:18 AM
dohctor_B's Avatar
Default JDM gauge cluster problem. HELP!!!
Ok, so i recently bought a JDM gauge cluster for my 94 civic ex. Here's the problem.... My car came equipped with ABS and SRS. The JDM gauges don't have the connections for these two plugs but i figured that didn't matter. But than it snowed last night, so i took my car out to test my ABS. It didn't work!!! Does this mean my SRS(airbags) is not functional as well with this JDM cluster? Is there any way to make it so my ABS will work again or my SRS(with this cluster)? Do the JDM clusters even come with a spot for an ABS plug?!?!? need help please
Old Dec 10, 2005 | 06:24 AM
dohctor_B's Avatar
Default Re: JDM gauge cluster problem. HELP!!! (iSRT_Vtec)
bump, need some help
Old Dec 10, 2005 | 07:28 AM
egryda's Avatar
bump cause im curious as well.
Old Dec 10, 2005 | 07:33 AM
dohcVTECeg2's Avatar
Default Re: JDM gauge cluster problem. HELP!!! (egryda)
i got a del sol sir cluster no abs
Old Dec 10, 2005 | 09:29 AM
built562's Avatar
Default Re: JDM gauge cluster problem. HELP!!! (dohcVTECeg2)
damn that sucks, you replace a cluster and you los abs. i didnt know that.
what about if you switch the housings? like take out the gauges from the JDM cluster and put them in the usdm housing?
Old Dec 10, 2005 | 10:49 AM
civichbcx's Avatar
Default Re: JDM gauge cluster problem. HELP!!! (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">
what about if you switch the housings? like take out the gauges from the JDM cluster and put them in the usdm housing?</TD></TR></TABLE>
That's actually a good idea.....I don't see why it wouldn't work. That's what I would recommend. Good luck!
Old Dec 10, 2005 | 11:15 AM
cxSHOE's Avatar
if you still have your oem cluster, you need to take out the connector plugs from that cluster and clip them on your car side connectors.. in other words you need to have it plug it in order for them to work.
here is my jdm eg6 cluster with my oem srs switchout. and plugged from behind. and it works fine. i dont think there is an open slot for your abs on the jdm cluster. so just take out the actual chip board from your old cluster hook it up to the plug, and then put tape over the chip board and let it hang behind the cluster and it will work... it has to be plugged into its chip board for it to work. same goes for cruise control, which does fit in the back of the jdm cluster but you wont be able to see the light since theres no opening on the front.
Old Dec 10, 2005 | 11:46 AM
dohctor_B's Avatar
Default Re: JDM gauge cluster problem. HELP!!! (cxSHOE)
thanx alot guys, i think i'll try doing the connecter plug thing. The stock housing with JDM guages hybrid is also a good idea. Thanx for all your advise
Old Dec 10, 2005 | 12:11 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
LOL!!! I thought that said 240 mph at first, i was like woah, i don't think so.
Old Dec 10, 2005 | 12:18 PM
H23Si_PRELUDE's Avatar
Default Re: JDM gauge cluster problem. HELP!!! (Tippyman98)
haha me too
utturkey
May 25, 2011 05:42 PM
ivicr
14
May 2, 2009 10:01 AM
tommymoose
Aug 15, 2005 01:48 PM
Lyonel
Feb 27, 2002 06:59 PM
