Ratteling after installing B&M Short Shifter
Old Dec 9, 2005 | 11:03 AM
PiXeL's Avatar
Default Ratteling after installing B&M Short Shifter
Hi all,
First of all the short shifter is nice but I hate it because its straight... The ones with the original bend would be better...
Anyways, I have weird rattelling sound after installing it.
Especially when driving on low RPM and trying to accelerate.
I checked underneath the car today, and when I move the stick from side to side there is some clicking sound, but I couldn't understand where it was coming from...
Any ideas what could be the problem?
Old Dec 9, 2005 | 11:14 AM
SicilianSpeed42's Avatar
my guess is its hittin your exhaust
Old Dec 9, 2005 | 11:16 AM
BanEL's Avatar
Default Re: (SicilianSpeed42)
did u install the spacers between the shifter and the linkage?
Old Dec 9, 2005 | 11:24 AM
elitesi8's Avatar
Default Re: Ratteling after installing B&M Short Shifter (PiXeL)
I Had the same poblem, its just hitting your Exhaust, you can either bend the hangers down a little or get longer rubber pieces for the hangers. 2 cents
Old Dec 10, 2005 | 11:49 AM
dwnthehatch's Avatar
Default Re: Ratteling after installing B&M Short Shifter (elitesi8)
Did you put the metal sleeve with rubber o-rings from your old shifter into the new one?
Old Dec 20, 2005 | 08:24 AM
PiXeL's Avatar
Heres a pic of what was left after the installation:
the 3 red o rings are for interga only
the 4 black ring are replaces with new ones from the b&m kit
There was no info about the two black rings/spacers at the instruction and I couldnt get them in...
(There is some other o-rings that goes at the same place)
Maybe that the problem?
Old Dec 20, 2005 | 10:22 AM
tracebuzta's Avatar
when mine rattles i just go under and tighten the bolts holding the shifter in there, always works for me
Old Dec 20, 2005 | 11:39 AM
PiXeL's Avatar
Default Re: Ratteling after installing B&M Short Shifter (tracebuzta)
Mine was rattelling from the first day I installed it...
Did you put back the 2 black rings/spacer that in the pic?
Old Dec 20, 2005 | 12:37 PM
jadugartir's Avatar
those 2 black rings have to be left off cuz they only fit on the oem shifter.
Old Dec 20, 2005 | 01:20 PM
emotionisdead's Avatar
Very Emergency!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicilianSpeed42 &raquo;</TD></TR><TR><TD CLASS="quote">my guess is its hittin your exhaust</TD></TR></TABLE>
that is what my old skunk2 one did on my integra. it was so annoying.
Old Dec 20, 2005 | 02:43 PM
I8Stang's Avatar
Default Re: (emotionisdead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicilianSpeed42 &raquo;</TD></TR><TR><TD CLASS="quote">its hittin your exhaust</TD></TR></TABLE>
Old Dec 20, 2005 | 03:41 PM
northkai3's Avatar
Default Re: (I8Stang)
instead of tightening it all the timejust put some lock tight on there otherewise ur gonnadrop ur linkage and be stuck in gear or out whatever
Old Dec 20, 2005 | 08:46 PM
PiXeL's Avatar
If I remember right there is a lot of clearance between the exhaust and the shifter.... thats the first thing I checked....
Anyways I'll check it again... Thanx
Old Dec 20, 2005 | 08:51 PM
shyboi4u's Avatar
Default Re: (PiXeL)
mine did the same thing. but mine wasn't hitting the exhaust. the bolt was rattling inside the shifter. i'm guess the o-rings that fit on the collar was to small. i decided to take the shifter out.
Old Dec 20, 2005 | 09:34 PM
E.Honda's Avatar
Default Re: (PiXeL)
I have the same shifter..No rattles or problems.
Modified by E.Honda at 2:29 AM 12/21/2005
Old Dec 20, 2005 | 11:20 PM
resol's Avatar
Default Re: (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda &raquo;</TD></TR><TR><TD CLASS="quote">I have the same shifetr..No rattles or problems.</TD></TR></TABLE>
x2
Old Jan 11, 2006 | 04:11 AM
PiXeL's Avatar
I just istalled a new Skunk2 shift ****, and guess what? The rattelign stopped!!
I still don't know if the problem was with the old shift **** (apc crap) or with the B&M shifter and the extra weight of the Skunk2 know stopped it...
Old Jan 11, 2006 | 04:37 AM
1SickEG's Avatar
I also had the same problem...but i didnt install a short shifter i just put a stock one back on and i didnt do sumthin right and when i would give it throttle it would rattle...it was just hitting the exhaust
Vovchandr
Mar 29, 2006 11:41 AM
kaychi
Oct 6, 2005 01:24 PM
Suzukablue
Jan 30, 2005 07:04 PM
Civic92Turbo
Jun 27, 2004 05:43 PM
JamesQ
Nov 24, 2003 02:22 AM
