quick question i must know.
Old Dec 9, 2005 | 08:51 AM
Alex9386's Avatar
Default quick question i must know.
Last night i was racing an is300 with my 05 dc5. I was in third and went to second instead of fourth. Of course, the RPM's maxed out and i was just wondering if that is really that bad. I have about 10500 miles on it. Its the first time its ever happened to me. Just let me know, thanks.
Old Dec 9, 2005 | 10:33 AM
02ep3's Avatar
Default Re: quick question i must know. (Alex9386)
i mean its obviously not good for it but i dont think your car will explode because of it....i was with my friend and he missed a gear in his itr and shot his revs up past 9 or 10.....its still runnin strong as hell. i know you didnt ttry to do it, just dont do it agian, u;ll be aight
Old Dec 9, 2005 | 11:26 AM
Red05TypeS's Avatar
i did it in my 05 rsx-s too at the track. 8400 rpm in 3rd and threw 2nd. nothing happend, you got like a 50/50 chance of dropping a valve and destroying your motor tho. just don't do it again.
Old Dec 9, 2005 | 12:11 PM
01-1293's Avatar
Default Re: quick question i must know. (Red05TypeS)
I did this with my old type r and did $4,000 damage CAD to the motor.......most common bad things that could happend are bent valves + spun rod bearing
Old Dec 9, 2005 | 12:32 PM
EP3tune2RULE's Avatar
I have done it a few times as well in my EP3... Still running like the day I got it... Just a bit faster....
Old Dec 9, 2005 | 01:13 PM
NJslvrtypes's Avatar
Well, if you are worried go do a compression and leak down test. Or better yet pull the head and have a look. Chances are if you did not throw a cel or the motor is running ok then you may have lucked out. This all depends on how high you over revved.
Old Dec 9, 2005 | 02:54 PM
The Tech-1's Avatar
Default Re: quick question i must know. (01-1293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-1293 &raquo;</TD></TR><TR><TD CLASS="quote">most common bad things that could happend are bent valves + spun rod bearing</TD></TR></TABLE>
Yup
Old Dec 10, 2005 | 12:23 AM
hushypushy's Avatar
heh, 3 to 2 is a weird mis-shift, just pull straight down 3--&gt;4
(it's ok im not making fun of you've ive done 4-3 mis shift before)
Old Dec 10, 2005 | 07:51 AM
djSALIX's Avatar
how long did you stay in 2nd before you pushed the clutch in?
If it was longer than a second or two, you WILL have problems soon.
Old Dec 10, 2005 | 07:57 AM
BoBoChan's Avatar
Default Re: (hushypushy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hushypushy &raquo;</TD></TR><TR><TD CLASS="quote">heh, 3 to 2 is a weird mis-shift, just pull straight down 3--&gt;4
(it's ok im not making fun of you've ive done 4-3 mis shift before)</TD></TR></TABLE>
fer real, 3rd to 4th is vertical, thats fukked up
4 to 3 is a little understandable but 3rd to 2nd, what the fack y0
Old Dec 13, 2005 | 06:43 AM
greddydc5's Avatar
A friend was driving my car and he did the same thing, since then my valves have been clicking louder, I think I just need to do a valve adjustment???
b20bFourDoorCivicLX
Apr 21, 2012 06:43 PM
ZTYPE_S
35
Feb 24, 2004 07:12 AM
vtecngsr
Jul 5, 2003 06:12 PM
RedGSRBull
Jun 16, 2003 09:49 PM
Nuts
Nov 14, 2001 07:31 AM
