B18B1 (Integra LS) valve cover oil leak problems
Old Dec 9, 2005 | 04:14 AM
J.nguyen's Avatar
Default B18B1 (Integra LS) valve cover oil leak problems
Ok, we'll I was leaking oil on my valve cover gasket kit so i got a new kit with new everything ( including O rings ). Put it on, stopped the valve cover gasket leaking, but when i did a valve adjustment, i found out when i pulled my sparkplug wires out, oil was in there. So then i used honda bond or whatever and sealed back my valve cover gasket kit. Few months later, i test to see if im still leaking oil in there, and it is still leaking into my spark plug wires, all 4. What can fix this? i tried searching but i did what it was told to do.. i dont have a hole in my block or head or wahtever because my motor runs pretty strong. I hear if i get new washer where the bolts on valve cover go, it might fix it because the washers tend to get flat over the years? someone help please because i am planning on going turbo and dont want oil leaks..
Old Dec 9, 2005 | 04:32 AM
KooK's Avatar
Mustang Sally
Default Re: B18B1 (Integra LS) valve cover oil leak problems (vietblood129)
If it were me, personally I would replace the 4 sparkplug gaskets on the valve cover, put it back on and torque it down to factory spec. Typically the cause for a leaky valve cover is something is too tight, or not tight enough. Either way, I'd use Honda Bond once again but an EXTREMELY thin layer of it, just to make sure you will have no problems. It's about all you can do unless your valve cover is cracked or something.
Old Dec 9, 2005 | 09:38 AM
J.nguyen's Avatar
help
Old Dec 9, 2005 | 09:57 AM
yee SERIOUS's Avatar
replace those spark plug groumets (sp?).
Old Dec 9, 2005 | 01:48 PM
J.nguyen's Avatar
Default Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">replace those spark plug groumets (sp?).</TD></TR></TABLE>
the "o" rings right.. they were replaced.. is it not because of the washers??? someone plz help
Old Dec 10, 2005 | 01:32 PM
J.nguyen's Avatar
Default Re: (vietblood129)
nobody knows the answers??? wtf!!
Old Dec 11, 2005 | 05:45 PM
J.nguyen's Avatar
help me uncle fcker!!!
Old Dec 11, 2005 | 08:38 PM
no2unenolife's Avatar
u sure u put enough silicon/ honda bond on there?
Old Dec 13, 2005 | 12:12 AM
J.nguyen's Avatar
Default Re: (no2unenolife)
yeah,... is it the WASHERS ON THE VALVE COVER?? I HEAR THEY GET BENT FROM YEARS OF TIGHTENING AND UNTIGHTENING
Civic_07
29
Jul 6, 2009 06:05 PM
the king.
12
Feb 3, 2009 08:29 PM
J.nguyen
Nov 24, 2005 08:12 PM
CivicVX94
Aug 7, 2005 04:22 PM
mulpha
Jan 14, 2004 04:01 AM
