gauge e-brake light wont turn off
Old Dec 8, 2005 | 06:57 PM
i drive a prelude sh's Avatar
Default gauge e-brake light wont turn off
My e-brake light on my gauges stays ON even when my e-brake is down. untill i get on the freeway it takes like a couple minutes till it turns off. when i get to a stop, sometimes is turns back on. ANY SUGGESTIONS?? PLEASE HELP!!
Old Dec 8, 2005 | 07:20 PM
Brown-tec's Avatar
Default Re: gauge e-brake light wont turn off (i drive a prelude sh)
i had the same problem this morning i dont know either!
Old Dec 8, 2005 | 07:25 PM
Jago's Avatar
Default Re: gauge e-brake light wont turn off (Brown-tec)
there ar two things this could be one your brake fluid is low. Or the brake fluid
resivor sensor is bad. It is part of the resivor cap if you look it has two wires coming out of it
Old Dec 9, 2005 | 12:17 AM
4LugR's Avatar
Default Re: gauge e-brake light wont turn off (Jago)
yep.. add brake fluid
Old Dec 9, 2005 | 04:56 AM
junbb1's Avatar
Default Re: gauge e-brake light wont turn off (AEMPrelude916)
there is a S/B to replace the sensor only and the filter. Your local Honda dealer will have the parts in stock. very common. very cheap repair.
Old Dec 9, 2005 | 05:49 AM
BergRacing21's Avatar
Default Re: gauge e-brake light wont turn off (junbb1)
i think my gauges are all f--ked up cause when my tailights go out my brake light stays, on isnt there suppose to be another light for that? either way i replace the bulb and then it cuts off.
Old Dec 9, 2005 | 06:54 AM
The_Sober's Avatar
Default Re: gauge e-brake light wont turn off (BergRacing21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junbb1 &raquo;</TD></TR><TR><TD CLASS="quote">there is a S/B to replace the sensor only and the filter. Your local Honda dealer will have the parts in stock. very common. very cheap repair. </TD></TR></TABLE>
what years, though?
Old Dec 9, 2005 | 06:08 PM
driftmaster04's Avatar
yea im gettin this too bugs the hell outa me sometimes it goes off and comes back on or itll stay on and ive got plenty of fluid in the rexevoir just checked it today.
Old Dec 13, 2005 | 06:29 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (driftmaster04)
I have a 93 Si and mine will stay on until i wiggle my ebrake and then it might come back on until i push it down a little with my hand. If I let the light stay on then my ABS light will come on, but once I shut the car off the light goes off.
Old Dec 14, 2005 | 08:07 AM
Black Raven
Guest
Posts: n/a
its the cold weather that causes this. Happen to me recently. The light only comes on in morning and goes away when the car is warm. U can solve the problem by cleaning the the wires on the ebrake handle, it sticky stuff gets stuck together when it gets cold which causes the light to stay on.
Old Dec 14, 2005 | 09:13 AM
Komakazi_830's Avatar
this happened to me like a month and a half ago...started a thread on it infact...it happens when it gets cold out...it stopped when i added fluid so i would say do that...
sirrjibbalott
Oct 23, 2006 09:25 AM
intech
Nov 17, 2005 02:44 PM
BigZ88
Feb 21, 2005 09:17 PM
vtec-izm
Aug 26, 2003 11:53 AM
pelotudo
Sep 25, 2002 07:11 PM
