help/horn doesnt work!
horn wont work. you need to find the plug/wire that goes to the hornand have to rig somthing up so the wire contacts the copper ring on the back of the hub.
had same prob with my horn. found a thick sheet of copper and cut a piece out bent it up so it reach from a screw hole. put a eye terminal on the wire and also attached it to the screw hole so it would contact the copper piece i made.
its for a DA, well let me decribe the steering wheel hub. The hub came with a four wire it has red black and yellow with green which i believe it was for the horn, and theres this last wire. other than the yellow and green which is screwed in the hub there was the 3 wires that has that copper end that hits the metal part from the steering column, since im not using the cruise control anymore, I took the other 3 wires, was that the right way or should i left those wire in there?
