turbo kit??
Old Dec 8, 2005 | 04:33 PM
mullins172's Avatar
Default turbo kit??
im planning on going the turbo route. i have no idea on where to get it. it will have stock internals for awhile. but i need to know if i will need to buy a new radiator to fit the turbo. any help will be appreciated.
Old Dec 8, 2005 | 04:51 PM
teg racer 877's Avatar
Default Re: turbo kit?? (mullins172)
What motor are u planning putting a turbo on? Im also gonna put a turbo on my car (95 teg b18b) best price I have found is on ebay, its a brand new greddy kit that goes for $2100 with everything u need, (manifold, emanage, turbo, ext.) and the seller is legit, good store with phone # and everything, check em out.
Old Dec 8, 2005 | 04:55 PM
Default Re: turbo kit?? (teg racer 877)
Most of the time time u do not need to remove a/c if u run the cast manifolds that come with most kits (greddy, turbonetics, edelbrock), the time when u need to remove a/c is when u use a high flow mandrel bent manifold.
Old Dec 8, 2005 | 05:03 PM
JeffRocksYoSocks's Avatar
for the price the greddy kit is a really good kit. pushes some really good numbers. you dont have to remove anything really, it'll just be a tight fit. on top of that the best part is its smog legal.
Old Dec 8, 2005 | 05:37 PM
Default Re: turbo kit?? (argetni aruca)
Im not 100% sure, but I dont think the lower a/c lines get in the way of the I.c piping, they dont look like they would to me, you might need to grind the radiator support to let the piping thru though
Old Dec 8, 2005 | 05:57 PM
mullins172's Avatar
its the stock b18a in my 93 ls. so i dont have to buy a new radiator or new fans for the a/c and such?
Old Dec 8, 2005 | 06:15 PM
XxDJCyberLoverxX's Avatar
I'm actually looking at the GReddy turbo too for my stock GSR. Just wanna keep my internals relatively stock, 'n run about 220 whp after tuning. I know fuel components needs attention, but do I need an aftermarket radiator too, to keep the temperatures down?
Would the valvetrain and bottom ends need attention if I want to make that kind of power?
Old Dec 8, 2005 | 06:39 PM
Johnny_Rocket's Avatar
My stock radiator did not fit... It technically "fit" but once I started up the motor my wastegate slammed into the radiator and that was the end of that. It all depends on what manifold you choose.
Every application will be different and no two turbo setups are the same
Old Dec 9, 2005 | 02:20 PM
mullins172's Avatar
Default Re: turbo kit?? (JohnnyH)
i see, so what kit would you recommend? i was thinking turbonetics since it seems that none of the other companies offer a complete kit, but i dont know...
Old Dec 9, 2005 | 02:27 PM
gsr2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mullins172 &raquo;</TD></TR><TR><TD CLASS="quote">i see, so what kit would you recommend? i was thinking turbonetics since it seems that none of the other companies offer a complete kit, but i dont know...</TD></TR></TABLE>
How much do you have to spend and how much power in the long term?
Old Dec 9, 2005 | 04:39 PM
mullins172's Avatar
Default Re: turbo kit?? (gsr2000)
well it just depends, there are cheap kits on ebay that are so called turbonetics. but if i had to buy one brand new i wouldnt want to spend more than 2500
Old Dec 16, 2005 | 12:09 PM
like I said above, brand new greddy kits on ebay for 2100 from a legit dealer of performance parts.
go to http://www.cityspeed.com for the online store
EduardoDC5
Jan 1, 2007 06:47 PM
jamie9500
Feb 24, 2006 01:32 PM
honda_coupe
Feb 9, 2006 06:05 AM
integraboi1010
Oct 27, 2004 01:08 PM
1990hondaHF
Sep 27, 2003 08:32 AM
