pullin the motor from a 89 integra ?
Old Dec 8, 2005 | 02:33 PM
st95accord's Avatar
Default pullin the motor from a 89 integra ?
To pull the motor from a 89 integra can you pull the motor out from the top? i was told it can only be done from the bottom... is this true? need answer asap please.
Old Dec 8, 2005 | 05:28 PM
jdmcars.com's Avatar
Default Re: pullin the motor from a 89 integra ? (st95accord)
The engine can be pulled from the top or bottom. Depending on what were is being done, and the set up for working is the answer of which is easier.
I would think most DIYers pull it from the top. Here are some quick tips, not everything that should be done, not shown in any order...
Unplug wiring from clips on pass side shock tower, and drivers side relay box
Disconnect fuel and any vacuum lines, speedo cable
Pull axles out away from engine/trans s-or remove completely
Remove shiftlinkage from trans side
Remove rad
Unbolt engine and remove
Old Dec 8, 2005 | 07:04 PM
Johnny_Rocket's Avatar
Default Re: pullin the motor from a 89 integra ? (jdmcars.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com &raquo;</TD></TR><TR><TD CLASS="quote">
Remove rad
Don't forget to unhook the exaust and the heater core lines
rbizzell30
Acura TL, RL & ZDX
Sep 20, 2011 05:54 AM
jaymua
Jan 31, 2009 08:51 PM
rustydusty1717
52
Oct 7, 2008 04:25 PM
spooty
Sep 9, 2008 03:32 PM
K24EK
Honda Civic (2006 - 2015)
18
Jul 31, 2007 12:14 PM
