GSR rods and Crank in an LS Block?
Old Dec 8, 2005 | 02:30 PM
efstile's Avatar
Default GSR rods and Crank in an LS Block?
Can it be done. im trying to build a boostable, low budget ls bottom end for my del sol. im bolting a b16 head on it so i have to careful with compression. so can i use gsr rods and crank? most likely going with stock pistons and rods. any good ideas for a cheap ls block w/ a b16 head and boost?......let me know.
Old Dec 8, 2005 | 03:24 PM
RaceCarRyne's Avatar
Default Re: GSR rods and Crank in an LS Block? (efstile)
if you use the gsr rods and crank it is making that ls block the same thing as a gsr... because they share the same bore but the gsr stroke is shorter than the ls so you will also be loosing displacement.. if you are looking for boost just boost the ls.. plenty good enough... already low compression too...
Old Dec 8, 2005 | 03:36 PM
efstile's Avatar
the ls block has nothing in it though. trying to get a god idea of what i should build. that was obviously my first guess. anyone have any other ideas?
Old Dec 8, 2005 | 06:11 PM
mmuller's Avatar
Mad Scientist
keep your bigger stroke
carlossolorzano
May 27, 2012 01:12 AM
EF9SIRJeff
Aug 24, 2005 11:07 AM
BlkslowCRX
12
Feb 9, 2005 10:18 PM
electric_rex
Dec 5, 2004 02:57 PM
NathanMorris
Nov 30, 2004 10:01 AM
