SK2 Stg2/blox Stg 2 cams
Hi
Anyone one here have experience running these cams? Hows the driveability with these cams? Hows the idle? Anyone made good power with these cams? Im deciding if i should go with these cams because im having a hard time finding JUN III's.
Thanks
Thanks
No you just put either the USDM or the JDM. Preferably the JDM because it has more compression, which will lead to others being confused as well. You don't have to be a ***** about it, I was just clearifying so people would know what your talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black cx »</TD></TR><TR><TD CLASS="quote">Hi
Thanks</TD></TR></TABLE>
Skunk Stage II cams are waaaaaaaaaaay bigger than the BCII. Idle on both should be fine assuming you've got the idle AFR dialed in. I would suggest the BCII's if it's just a mild street application.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver j »</TD></TR><TR><TD CLASS="quote">he said blox, not buddy club.</TD></TR></TABLE>
My bad. Same result.
I agree that the pro 1+ would be a better choice.
