need help disc brake swap
Old Dec 8, 2005 | 01:16 PM
hondaefhatch89's Avatar
Default need help disc brake swap
i have a 89 civic hatch and i got a set of rear brakes off a 91 integra does it bolts right up andl i need to know is how to do the e brake cable
Old Dec 8, 2005 | 01:47 PM
Mr_Si-R's Avatar
you also need the master cylider dron the da and you need crx si e-brake cabels
i was going to do this also, but i dont have the time being a full time student
Old Dec 8, 2005 | 01:50 PM
civickiller's Avatar
Default Re: need help disc brake swap (hondaefhatch89)
you take off the trailing arm then you replace it with the teg trailing arm. ebrake cable, you take off the stock cable and put on the integra cable. doesnt get much harder than that.
the only thing you gotta worry about is the compensator arm at the front of the trailing arm because where the compensator arm bolts onto the chassis is a alignment point so if you move it then you gotta get your alignement done
oh and how are the tailing arm bushings on teh integra trailing arm? cracked?
Old Dec 8, 2005 | 02:02 PM
JK_Motorsports's Avatar
Default Re: need help disc brake swap (civickiller)
You don't need the master cylinder. It's nice to go to a bigger one, but not necessary. But you'll want it if you go to DA front brakes.
I highly recommend getting the Proportioning Valve.
CRX E-Brake Cables don't work on a hatch, You'll need the DA Teg ones. I found this out the hard way.
Keep the Civic Lower Control Arms, front compesator arm, and Upper Compensator arm. If you do, you shouldn't have alignment issues. But I can't quarenty that.
I haqve done this swap on a few cars, mine and and some friends. These are the things you learn. It's not hard, basically 5 bolts, E-Brake Cables, and Brake Lines and your good to go.
B_Swapped93
Jan 15, 2014 07:46 PM
GI8U2racing
Mar 3, 2007 06:33 AM
DaCRXboi
Aug 19, 2006 01:23 PM
crexer
Sep 7, 2004 08:26 PM
CRexcellence
Nov 20, 2003 06:26 PM
