Is it possible to Re-Thread axle studs?
I stripped many studs on my axle while taking off and putting back on wheels. Is it possible to just re-thread them instead of buying and installing new ones? Any help is appreciated!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">I dont see why you couldnt, with a die, <u>as long as theyre not too bad</u>
Good luck finding one thats the correct size</TD></TR></TABLE>
Why, are they hard to find?
oh studs? You said axle, so I figured the big *** threaded portion of the axle
Either way, from my experience, most places wont have the metric dies. Be very sure that theyre going to be safe after you "fix" them...
If you've stripped the threads....I would just suggest you replace them with some factory or reliable aftermarket studs. Like he said "it's hard to find metric." Goodluck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichbcx »</TD></TR><TR><TD CLASS="quote">I would just suggest you replace them with some factory or reliable aftermarket studs. </TD></TR></TABLE>
ARP studs would be a good choice, seeing many use them....
here an FAQ in case you do it yourself https://honda-tech.com/zerothread?id=907985
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sockvtec »</TD></TR><TR><TD CLASS="quote">
Same way i do the job. Works every time
</TD></TR></TABLE>Same way i do the job. Works every time
Thanks for all the input. Don't have time, that's the problem, however, if it means my safety in all of your opinions I guess I will HAVE to make time. Thanks!
Ivan
28
Jul 1, 2003 07:49 PM
