92 Teg idling at 1200 rpms.....no code...vacuum leak?
Old Dec 8, 2005 | 06:17 AM
Vtak DOHCTA's Avatar
Default 92 Teg idling at 1200 rpms.....no code...vacuum leak?
Like title says.....I have a b16 in the car...it's obd1 so all the vacuum lines and **** are on the manifold....just trying to figured out what the deal is....it should be idling at 600 i thought...any ideas would be great....hit me!!
Old Dec 8, 2005 | 06:32 AM
projectTeG's Avatar
fit valve might need the platic screw inside screwed back down. vacuum leak or one of the lines are ran wrong.
Old Dec 8, 2005 | 03:09 PM
it's hard to tell which it is because it's so random and inconsistant...someone mentioned the eacv valve going bad....he claimed that sometimes it doesn't throw a code....where can I get a good diagram of how to run these vacuum lines? the chiltons manual I have kinda sucks
Old Dec 8, 2005 | 03:13 PM
projectTeG's Avatar
try opening up the flat side of the fit valve and screw the plastic screw back in and clean the iacv out with carb cleaner
Old Dec 8, 2005 | 03:19 PM
ok i'm not too dumb about this stuff but what is the
fit valve?
Old Dec 8, 2005 | 03:20 PM
loudassVTEC's Avatar
Default Re: 92 Teg idling at 1200 rpms.....no code...vacuum leak? (VtAkMn)
check vacuum hoses, clean the iacv, screw the little plastic screw in on the fitv, then check your idle screw. If the doesnt fix it, pull the throttle body, and replace the gasket. If that doesn't work, pull the manifold, and replace that gasket. If that doesn't work, check the pcv valve.
I had the same problem with my b16 powered DA, and it was the throttle body gasket.
Old Dec 8, 2005 | 03:25 PM
projectTeG's Avatar
Default Re: (VtAkMn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtAkMn &raquo;</TD></TR><TR><TD CLASS="quote">ok i'm not too dumb about this stuff but what is the
fit valve? </TD></TR></TABLE>
fast idle thermo valve....its under the throttle body
you have to remove the tb to get it off easy, and it would be a good time to replace the TB gasket
Old Dec 8, 2005 | 03:26 PM
same here....got a new gasket on it......i'm pretty sure the hoses are run right, maybe one of the hoses are just bad like a hole is in it or something.........
temp's Avatar
Default Re: 92 Teg idling at 1200 rpms.....no code...vacuum leak? (loudassVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">check vacuum hoses, clean the iacv, screw the little plastic screw in on the fitv, then check your idle screw. If the doesnt fix it, pull the throttle body, and replace the gasket. If that doesn't work, pull the manifold, and replace that gasket. If that doesn't work, check the pcv valve.
I had the same problem with my b16 powered DA, and it was the throttle body gasket.</TD></TR></TABLE>
i would check the PCV valve before replacing any gaskets
Old Dec 8, 2005 | 03:45 PM
Default Re: 92 Teg idling at 1200 rpms.....no code...vacuum leak? (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
i would check the PCV valve before replacing any gaskets</TD></TR></TABLE>
Sorry, all those suggestions are off the top of my head, and are not in order. But yes, check the pcv valve before spending money on gaskets
Old Dec 8, 2005 | 03:55 PM
thanx guys i'll let you know
Old Dec 8, 2005 | 04:06 PM
projectTeG's Avatar
thats a good idea.make sure there are no rips in the hose and it sealed in the grommet right.
Old Dec 10, 2005 | 12:07 PM
replaced pcv valve and still high idle.....
Old Dec 10, 2005 | 12:15 PM
projectTeG's Avatar
did you inspect the hose for rips or not being connected right?
Old Dec 10, 2005 | 12:56 PM
i checked for holes or rips....no sign....I'm pretty sure they'v been run correctly....but not positive....maybe if someone could post a pic of they're engine bay, i could confirm if it's right or not....
Old Dec 12, 2005 | 06:18 AM
perhaps my iacv is bad....i could change that out
UniqueX707
Nov 3, 2011 08:42 AM
DA3
Sep 6, 2008 09:40 PM
onefastjew
Jul 9, 2007 06:19 PM
thundergrey94ls
Jul 9, 2005 04:43 PM
GSRvtecTEGRA
Aug 1, 2004 12:05 PM
