HELP: Clutch pedal making noises.....
Old Dec 7, 2005 | 11:50 PM
cirrus's Avatar
Default HELP: Clutch pedal making noises.....
everytime i press on the clutch pedal....it'll make loud squeeky noises...
any body know what the problem could be? and how to fix it?
Old Dec 8, 2005 | 01:26 AM
1QuikSOHCZC's Avatar
Default Re: HELP: Clutch pedal making noises..... (cirrus)
my clutch does that all the time havent had a problem at all...does it more when it rains....its been like that since 03 so i jus forgot it was even there
Old Dec 8, 2005 | 08:10 AM
cirrus's Avatar
Default Re: HELP: Clutch pedal making noises..... (1QuikSOHC)
wow....been doing that for so long?
I cant handle it!!....it gets real annoying...
somebody pls HELP!!
Old Dec 10, 2005 | 08:39 AM
cirrus's Avatar
come on...anyone?
Old Dec 10, 2005 | 08:44 AM
RA61825's Avatar
Default Re: (cirrus)
mine those that shiz too ,exactly it does itm ore when it rains i tend to forget about it . and jsut listen to music lol
-jozer
sohc zc
Old Dec 10, 2005 | 09:23 AM
jDm bEeZy's Avatar
Default Re: (RACERX72)
mine does it too. no interior and no radio, always driving with the windows and sun roof down, while blowing the heater the whole time.. it just mixes in with all tha noise
Old Dec 10, 2005 | 09:24 AM
Mach69's Avatar
Get a new clutch cable.
Old Dec 10, 2005 | 09:41 AM
Coltmorris's Avatar
Default Re: HELP: Clutch pedal making noises..... (Mach69)
My pedal did that really bad..and was very stiff also..the pedal spring was messed up and the cable was bad.i replaced both and sprayed some white lithium grease on it and nows its perfect no noise and its super smooth
Old Dec 10, 2005 | 09:49 AM
SD_Lurker's Avatar
HT White Ops
Ya I suggest that you lube it down. If that does not help get a new clutch cable and spring and ake sure you lube it up before reinstalling. Good Luck
Old Dec 10, 2005 | 11:27 PM
supracrx's Avatar
Default Re: HELP: Clutch pedal making noises..... (nicks_jdmstyle_ef9)
hey guys u say to replace the clutch cable...how hard is it to remove the clutch cable? it just slides right oout..and looks fairyly simple or am i wrong? is there a special way of removing it?
Old Dec 11, 2005 | 12:17 AM
nelsmar's Avatar
Fairly simple 5-10 min job, just slides outof pedal and pull out through firewall.... you will want ot remove it from the transmission first. turn the adjustment **** until it is loose and pull it out
Old Dec 11, 2005 | 06:18 AM
realdealryan's Avatar
Default Re: (nelsmar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coltmorris &raquo;</TD></TR><TR><TD CLASS="quote">My pedal did that really bad..and was very stiff also..the pedal spring was messed up and the cable was bad.i replaced both and sprayed some white lithium grease on it and nows its perfect no noise and its super smooth</TD></TR></TABLE>
Exactly. And you probably don't have to replace the cable unless you've had to adjust it lately or it feels inconsistent. I would go get white lithium grease and spray up under the dash....
Old Dec 11, 2005 | 08:55 AM
supracrx's Avatar
how hard is it to adjus tthe clutch cable?
Old Dec 11, 2005 | 04:41 PM
Coltmorris's Avatar
Default Re: (supracrx)
well its not hard at all...theres a little nut and you just turn it with your hand. Loosen the nut to make your clutch catch lower..and tighten to make it catch higher. Squeaking is tough usually after you lube it doesnt go away you have to move it around a good amount for it to take the squeak out. But do the cheapest and easiest thing first..lube..then replace cable..then spring..and so on
ej6kid
Sep 30, 2010 01:15 PM
omgwtfbbqcrx
13
May 12, 2006 10:13 AM
[626]95-GSR
11
Jun 24, 2003 11:48 AM
Quik89Si
Mar 12, 2002 07:07 PM
Chip398193
Aug 31, 2001 03:54 AM
