B serise swap question
Old Dec 7, 2005 | 11:46 PM
crxsi8's Avatar
Default B serise swap question
will the DA 91-93 integra motor mounts fit 91 crx? whats a good ecu for OBD0 b16..
Old Dec 8, 2005 | 12:07 AM
31flavorscivic's Avatar
Default Re: B serise swap question (crxsi8)
You need custom engine mounts. Hasport sells them. DA mounts will not work.
Old Dec 8, 2005 | 12:18 AM
crxsi8's Avatar
thanks man aprreciated? some F**KER is selling me a JDm b16 w/LSD and he says the DA mounts a direct bolt on!
Old Dec 8, 2005 | 04:29 AM
tangerinebeast's Avatar
not really a F**KER for saying that but you can get them to work just modification and i hope u know there is no direct bolt in bseries swap you have to take off front mount on cm dent the driverside inner fender to fit alternator etc... just look it up lots of write ups on how toos also if it is a lsd tranny i would recomend going with hasport axles also since they are the correct length and since your getting the swap and didnt know the mounts wouldnt fit look down at the trans and look through the diff. where the axles go and if you can see through it then it is LSD if not he is lying not being smart *** just helpin
Old Dec 8, 2005 | 04:49 AM
b18_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 &raquo;</TD></TR><TR><TD CLASS="quote">will the DA 91-93 integra motor mounts fit 91 crx? whats a good ecu for OBD0 b16..</TD></TR></TABLE>
in japan it will
CRX_SedanED4
Jul 24, 2008 08:27 AM
EJ6SON
Classic Hondas
17
Jun 8, 2008 12:08 AM
Modern91Hatch
22
Dec 22, 2005 12:27 PM
GetawayInMoscow
Apr 18, 2005 11:11 AM
