RSX Type S Transmission problems?
Old Dec 7, 2005 | 10:13 PM
DFWRSXS's Avatar
Default RSX Type S Transmission problems?
I'm reading that the RSX reports a lot of transmission problems. Stuff about 2nd gear grinding and 3rd gear pop out. I hear its mostly on the base model RSX, but I've experienced the 3rd gear pop a few times in my Type-S. Are many people having the same problem? Anyone know what needs to be replaced in order to fix these problems? Any info please
Old Dec 8, 2005 | 06:07 AM
ekferio's Avatar
take it to the dealer, they should fix it free (if they can replicate the problem...good luck)
Old Dec 8, 2005 | 07:20 AM
Slow EJ8's Avatar
Default Re: (ekferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekferio &raquo;</TD></TR><TR><TD CLASS="quote">take it to the dealer, they should fix it free (if they can replicate the problem...good luck)</TD></TR></TABLE>
Do that, if its under warrenty take it to them but make sure you take it at a time when it is happening so they can replicate the problem as ekferio said.
Also, for some reason I thought it was only the Type-S model... I thought that was the one the Service Bulletin was out for, not the base. Not 100% sure on that though.
Old Dec 9, 2005 | 12:50 PM
SpoonyDC5's Avatar
Default Re: (Slow EJ8)
i had the 2nd and 3rd gear solenoids go out on my rsx and i took it back and they "fixed" it no problem but its kinda doing it again and now im noticing the 3rd gear pop out........ it drives me nuts
Old Dec 9, 2005 | 01:15 PM
DFWRSXS's Avatar
Default Re: (SpoonyDC5)
Is yours the Type-S or Base Model?
Old Dec 9, 2005 | 02:52 PM
The Tech-1's Avatar
Default Re: (DFWRSXS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFWRSXS &raquo;</TD></TR><TR><TD CLASS="quote">Is yours the Type-S or Base Model?</TD></TR></TABLE>
My 3rd gear popped out one day, i kinda pulled it a lil though but still I was quite shocked when it popped out. 06 Type-S here.
Old Dec 9, 2005 | 10:02 PM
NCNBPDC5's Avatar
Default Re: (The Tech-1)
Change your fluid to somethingl ike Redline or Synchromax...
i have had the TSB done....and a major tranny rebuild...and mine still grinds everyonce in a while....just be happy you have a NORMALLY smooth shifting gearbox. Alot of import guys cant say that.
Old Dec 9, 2005 | 10:11 PM
ekferio's Avatar
Default Re: RSX Type S Transmission problems? (DFWRSXS)
i had the base model before and no problem with the 3rd gear, but 2nd gear was notchy most of the time...now with my new 05 the 3rd gear goes further in with a slight pause sometimes
Old Dec 10, 2005 | 05:32 AM
96 SOHC VTEC's Avatar
I believe the problem is mostly with the Type-S model, not the base. My transmission has given me the third gear popout a good bit. I changed my fluid to GM Synchromesh and so far the pop-out hasn't happened yet. It still feels a bit notchy but I guess that's the way the tranny is. It's definitely smoother overall though.
Old Dec 10, 2005 | 06:53 AM
The Tech-1's Avatar
Default Re: (NCNBPDC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCNBPDC5 &raquo;</TD></TR><TR><TD CLASS="quote">Change your fluid to somethingl ike Redline or Synchromax...
i have had the TSB done....and a major tranny rebuild...and mine still grinds everyonce in a while....just be happy you have a NORMALLY smooth shifting gearbox. Alot of import guys cant say that. </TD></TR></TABLE>
I just got mine in Oct, it only has 2k miles. Should I just tell the dealer to change the fluid at the next scheduled service? I doubt they will though.
Old Dec 11, 2005 | 07:17 AM
SpoonyDC5's Avatar
Type-S here
ryanjvoss
Sep 27, 2010 08:39 AM
Civic92Turbo
Apr 16, 2008 01:10 PM
lilrabidmonkey
Sep 1, 2004 06:28 PM
jdmintegra1994
12
Nov 20, 2003 05:11 AM
Nuts
33
Oct 26, 2003 07:04 AM
