NEED HELP!TRANNY FLUID LEAK
Old Mar 14, 2002 | 08:49 PM
eg_nezay's Avatar
Default NEED HELP!TRANNY FLUID LEAK
MY TRANNY FLUID IS LEAKING FROM THE DRIVER SIDE AXLE.Could it be the seal or is it something else major? Also, my steering wheel wobbles when I drive it, could it be from the axles? yes , I checked my wheels and I just got my alignment done. Thanks in advance for the info.
ITS FIXED! IT WAS THE SEAL. IT HAD TOO MUCH TRANNY FLUID
AS FOR THE WOBBLE ITS CAUSE I WAS TOLD TO PUT WASHERS(FOR SPACERS) ON SO MY 14S WOULD FIT THE GSR BRAKE UPGRADE.BAD IDEA!
[Modified by eg_nezay, 1:08 AM 3/17/2002]
[Modified by eg_nezay, 1:12 AM 3/17/2002]
Old Mar 14, 2002 | 08:53 PM
DragII's Avatar
25 Year Member
Default Re: NEED HELP!TRANNY FLUID LEAK (eg_nezay)
most likely the seal.
make sure it's not CV grease..check your boots out.
Old Mar 14, 2002 | 09:32 PM
eg_nezay's Avatar
Default Re: NEED HELP!TRANNY FLUID LEAK (SuperDragII)
I know its not grease b/c I had to put a bucket underneath to catch the tranny fluid. does anybody know about the shaking on my steering wheel?could it be from a bad axle?
Old Mar 15, 2002 | 03:39 AM
Mista Bone's Avatar
D Tranny Guru
likely a bad bearing in the tranny, left side diff bearing.
Old Mar 15, 2002 | 08:54 PM
eg_nezay's Avatar
Default Re: NEED HELP!TRANNY FLUID LEAK (Mista Bone)
IM also trying to take off the driverside axle with that long shaft that connects to the tranny so I can repalace the seal but I cant take it off . Dont what to brake anything so anybody got any tips ? or I just got to pull/ hit it out?Thanks!
Old Mar 16, 2002 | 02:43 AM
Mista Bone's Avatar
D Tranny Guru
pry it away from the tranny with a screwdriver.
Old Mar 16, 2002 | 04:09 PM
eg_nezay's Avatar
IT WAS THE SEAL, AND ITS ALL BETTER NOW
em12nv
Feb 9, 2008 01:49 PM
shadohconspiracy
13
Nov 4, 2007 08:32 AM
97Alex
Mar 20, 2005 02:36 PM
