converting type r to obd1 with a magnetic key?
Old Mar 14, 2002 | 08:42 PM
b16aeg6's Avatar
Default converting type r with a magnetic key to obd1?
if you have a magnetic key, can you still convert a 01 type r to obd1. if you can how do u bypass the magnetic key or does the obd1 comp not look for it? please reply if you know anything about this topic or if you knwo anyone that can help me.
[Modified by b16aeg6, 6:05 AM 3/15/2002]
Old Mar 14, 2002 | 08:48 PM
b16aeg6's Avatar
Default Re: converting type r to obd1 with a magnetic key? (b16aeg6)
please help, i need to know if i can use it or not
Old Mar 14, 2002 | 09:12 PM
b16aeg6's Avatar
Default Re: converting type r with a magnetic key to obd1? (b16aeg6)
ttt
Old Mar 14, 2002 | 09:37 PM
Renegade's Avatar
I don' t think you can use withou the key but here is a post where someone talks about removing the immobilizer feature off the ECU
https://honda-tech.com/zerothread?id=145139
Old Mar 14, 2002 | 09:52 PM
Black R's Avatar
25 Year Member
.....You mean the immobilizer chip in the '00-'01 teg's?
If you convert to obd1, then you lose that feature.
Old Mar 14, 2002 | 09:56 PM
b16aeg6's Avatar
Default Re: converting type r with a magnetic key to obd1? (Black R)
i mean do the 01 integras have a chip in the key as a security? and if so how do i get around it if i wanna use a ecu jumper.
Old Mar 14, 2002 | 10:11 PM
t's Avatar
t
I am not 100% sure but the immobilizer is in the ecu, so using a jumper with a different ecu will delete the immobilizer
Old Mar 14, 2002 | 11:39 PM
Looose_R's Avatar
Default Re: converting type r with a magnetic key to obd1? (t)
t is correct
crxb16a90
Engine Management and Tuning
Mar 2, 2010 04:42 PM
Jap_Spec_Imports
Sep 15, 2008 01:25 PM
jdmland
Apr 6, 2008 05:20 PM
davidcrx89
Mar 11, 2005 08:12 AM
AW
Aug 29, 2002 07:33 AM
