Help ... need transmission advise
Old Dec 7, 2005 | 08:00 PM
Papa-Teg's Avatar
Default Help ... need transmission advise
While doing a burnout in my '96 Integra I busted a motor mount. That caused the motor to torque extremely to one side and twist the transmission. The torqe rod (shifter stabilizer) broke it's mounting boss off the transmission case and now there is a nice little hole in the tranny. Has anyone ever had this problem and if so how did you fix it?
I could plug the hole with JB Weld that won't keep the mounting boss in place.
The trans works great and I can't afford to replace it ... used ones are running $600 to $1,000.
Any ideas or suggestions would be great.
Thanks
Old Dec 7, 2005 | 08:52 PM
MajorPayne's Avatar
Default Re: Help ... need transmission advise (Papa-Teg)
you could try bending a small piece of aluminum to the same contour of the place where the hole is, but cut it a little larger than the hole, basically what youre doing is making a patch, then you can jb weld that on there and it should be fine, just dont get the jb weld in the trans
should that fail to work, take it to a welding shop, they can do it for you
Old Dec 7, 2005 | 09:10 PM
jh2586's Avatar
just buy the housing.. should be around $200 for a used one at a junk yard or something..
Russyo
Transmission & Drivetrain
Sep 8, 2011 05:24 AM
T76U13ALT
Welding / Fabrication
May 6, 2009 06:51 PM
cB7KiD
Aug 6, 2008 02:28 PM
BoltonGSR
Mar 22, 2008 06:09 PM
ki11a8ee
Oct 5, 2004 04:40 PM
