Help with deciding on what kind of motor mounts to buy! (Searched)
Ok guys, its this simple.
My rear motor mount is gone, and I want to just go ahead and replace all the mounts.
Now, OEM is expensive from local auto parts stores, and I know I could get some from a junkyard, but I really dont want to do that. So, with that said, what brand of mounts will give me a sturdier feel, but very very very little to NO (preferred) vibration throughout the car.
I've searched and haven't really found the answer im looking for.
From what I understand the energy suspension inserts cause hella vibration. I know it did on an old accord of my friends. I just want a comfortable, smooth idle without the excessive vibration. So, I guess what I'm looking for here is a direct answer or some kind of experience with a brand of mounts that doesn't cause vibration and is relatively close to OEM feel.
Thanks
Thanks
i had prothane inserts and they were frickin' irritating!! i couldn't stand the vibrations and removed them. i guess you can't beat the feel of OEM mounts-very smooth
ok . . . im glad your happy with your mounts, but i want to know is what aftermarket mounts can I buy that will be smooth and not shake the entire car. OEM is expensive new. I'd save just by buying an aftermarket set . .
Are the hasport mounts a good choice as far as in being smooth and having a smooth idle?
Have you tried getting the mounts from Len, if you haven't already. https://honda-tech.com/zerothread?id=1426478
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackRS »</TD></TR><TR><TD CLASS="quote">Are the hasport mounts a good choice as far as in being smooth and having a smooth idle?</TD></TR></TABLE>
They will make your car vibrate a bit more than stock but not too much more.
CRX MASE
Aug 29, 2009 08:54 PM
