22' slicks for 300whp?
Old Dec 7, 2005 | 05:55 PM
RaceProfessor's Avatar
Default 22' slicks for 300whp?
Just pondering on if 22x8x13's would be adequate for 300whp or should I upgrade to 23's or 24.5's. Anyone that used 22's on a 13' wheel with around that whp please respond with your experiences and the kind of 60's you're cutting. Thank you very much gentlemen.
Sam
Old Dec 7, 2005 | 06:41 PM
Supernatural's Avatar
Default Re: 22' slicks for 300whp? (RaceProfessor)
there was a video of some guys from florida running low 10s on 22's
turbo correct?
i think 22 will be adequate but not optimal
depends on your gears too
hondaefguy did 11's on 22's i think
Old Dec 7, 2005 | 07:14 PM
del slw's Avatar
this season i used 22x8x14's with 33*whp.
managed 11's.
what's the rest of your setup? can you handle hi launches with bigger slicks?
Old Dec 7, 2005 | 07:43 PM
nonvtecallmotor's Avatar
Default Re: (del slw)
Brian had 22x8x15 on the 00 si and that car ran 12.2 @111 w/ 1.81 60', but changed to 24.5x8.5x15 and went 119 with no other changes. Small tires just kill the top end.
Old Dec 7, 2005 | 07:44 PM
I would rather spin a bit rather than demolish drivetrain parts that's why I'm considering smaller slicks. I just want to be certain that it would work.
Old Dec 7, 2005 | 07:48 PM
Default Re: (RaceProfessor)
Alot of cars run stock axles. Axles will last if the car can make enough power to spin them a little bit. and a well set up car also helps.
Old Dec 7, 2005 | 07:54 PM
Default Re: (nonvtecallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor &raquo;</TD></TR><TR><TD CLASS="quote">Brian had 22x8x15 on the 00 si and that car ran 12.2 @111 w/ 1.81 60', but changed to 24.5x8.5x15 and went 119 with no other changes. Small tires just kill the top end.</TD></TR></TABLE>
Didn't Brian had to shift to 5th with the 22's?
Sam
Old Dec 7, 2005 | 08:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceProfessor &raquo;</TD></TR><TR><TD CLASS="quote">
Sam</TD></TR></TABLE>Yup but he did have res line at 7200 because of the LS, but it did have a LS trans also.
Old Dec 7, 2005 | 08:09 PM
Better stick with the 24.5's then. I was gonna ask you this too, when you went 1.65, were you on 22's or the big slicks?
Old Dec 7, 2005 | 10:29 PM
redskittle's Avatar
I post fake dyno charts
i went 10.9 @ 132 on 13 in lenso and 22in m&h.... hdm in orlando went 10.2 @ 139 on 22 in slicks and 15 inch rotas...they also went 142 mph on 22 inch slicks... but it depends on your set-up... go with the 22 inch.. youll be fine...
Old Dec 8, 2005 | 04:34 AM
nsxmatt's Avatar
22's will work fine but running 24's would be a better option just for the fact you won't be shifting into 5th. If you worried about drivetrain breakage run more tire pressure, at least you'll have room to grow if you make more power down the road.
For the record I ran 11.7's with my old car and 12.1 with the new one on 22x8's with 240 and 257whp and was needing more slick at that power level.
Old Dec 8, 2005 | 06:31 AM
Default Re: (nsxmatt)
Will I be able to keep it in 4th at around 120mph with an LS trans at 8500rpm on 13x22's?
Sam
Old Dec 8, 2005 | 09:16 AM
K20Ahondas's Avatar
I used 26" when I had 300whp.
Old Dec 8, 2005 | 09:43 AM
Default Re: (K20Ahondas)
Geezuz, Thanks Mr. Pro Racer and your 1200 lbs. with driver racecar . Just ******* with you dude! When are you planning on paying us a visit man, we got some new cars for ya. It's winter time so I know you're itching.
Sam
Old Dec 8, 2005 | 09:57 AM
Boostfed's Avatar
New User
2000 Civic Si Drag 3 turbo kit (Full WEIGHT Si)making 320 whp used 22x8x13 slicks went 12.0s with them, 60' times were 1.8s
Old Dec 8, 2005 | 09:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceProfessor &raquo;</TD></TR><TR><TD CLASS="quote">Better stick with the 24.5's then. I was gonna ask you this too, when you went 1.65, were you on 22's or the big slicks? </TD></TR></TABLE>That was in the CRX which I used 22x9.5x13. The best 60' in that car with those slicks where 1.61. On the 12.1 pass it spon a little bit. The next pass I blew the motor up from a miss shifting. I could of gottin it in the 11's with just a few more passes
Old Dec 8, 2005 | 10:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20Ahondas &raquo;</TD></TR><TR><TD CLASS="quote">I used 26" when I had 300whp. </TD></TR></TABLE>I use 26"'s with less then 300hp
Old Dec 8, 2005 | 02:33 PM
beaver's Avatar
I run 22x8's running mid 11's trapping 122+ on a b16 trans. A buddy of mine ran 11.2@128 on 22's as well on a gsr trans, both cars make over 400whp. You should be fine using them.
Old Dec 8, 2005 | 03:30 PM
Default Re: (beaver)
Did you have to shift to 5th?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaver &raquo;</TD></TR><TR><TD CLASS="quote">I run 22x8's running mid 11's trapping 122+ on a b16 trans. A buddy of mine ran 11.2@128 on 22's as well on a gsr trans, both cars make over 400whp. You should be fine using them.</TD></TR></TABLE>
Old Dec 8, 2005 | 03:32 PM
SlicksMH's Avatar
8.5/24.5-13 M&H
John@M&H
Old Dec 8, 2005 | 04:02 PM
LS_REX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceProfessor &raquo;</TD></TR><TR><TD CLASS="quote">Will I be able to keep it in 4th at around 120mph with an LS trans at 8500rpm on 13x22's?
At 7500rpm in 4th gear I was trapping about 118-120mph with the ls trans and 22's. You should have some room to play.
Rob
Old Dec 8, 2005 | 04:10 PM
LS_REX's Avatar
Default Re: (LS_REX)
I also cut consistent 1.69 - 1.70 sixty foots with those tires.
Rob
Old Dec 8, 2005 | 04:52 PM
hondaguyef's Avatar
Default Re: 22' slicks for 300whp? (NATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NATURAL &raquo;</TD></TR><TR><TD CLASS="quote">
hondaefguy did 11's on 22's i think</TD></TR></TABLE>
Yep, I've made 20+ 11 sec. passes all trapping 118-121 in 4th on a gsr trans. 121mph on GSR trans w/ 22's = 8450 RPM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS_REX &raquo;</TD></TR><TR><TD CLASS="quote">I also cut consistent 1.69 - 1.70 sixty foots with those tires.
Rob</TD></TR></TABLE>
Rob,
That's cause you're the ****! Where've you been?
Phil
Old Dec 8, 2005 | 07:13 PM
fmfkid250's Avatar
Ive used 22s vs 23s at the same track on the same day 1 after another and all and all the 23s performed better better 60's and dident loose any in the top
@ norwalk on the 23s vince barret was pulling 1.58 60's on the 23s w/ 205 whp
Old Dec 8, 2005 | 07:56 PM
SiKnezzALLmotor's Avatar
Default Re: (fmfkid250)
24.5 works great with mine considering im making 230whp and 155ftlb. of torque
LSVTEC 91 Civic
Apr 2, 2005 07:17 PM
BauleyCivic
Sep 11, 2004 09:49 PM
1320 sohc
Apr 20, 2004 12:37 PM
ACRXGuy
Apr 2, 2003 12:20 PM
1qWiKhAtCh
Jan 25, 2003 07:59 PM
