can i just put a cone filter on stock intake
Old Dec 7, 2005 | 05:44 PM
90babyblue's Avatar
Default can i just put a cone filter on stock intake
would this produce a gain, if i put a cone filter on my stock intake piping or am i better off just getting a stock air filter for that such restrictive air box. i would like anybodys input. i appreciate it.
Old Dec 7, 2005 | 05:53 PM
monzster's Avatar
get a k&n filter to fit your stock box or go with a cold air intake. get a true one though not one that sucks from under the hood and make sure you put a air bypass in it so you dont suck any water in it by accident
Old Dec 7, 2005 | 07:23 PM
cambopheonix56's Avatar
Default Re: (monzster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monzster &raquo;</TD></TR><TR><TD CLASS="quote">get a k&n filter to fit your stock box or go with a cold air intake. get a true one though not one that sucks from under the hood and make sure you put a air bypass in it so you dont suck any water in it by accident</TD></TR></TABLE>
The bypass valve only works if the filter is completely submereged so it will rarely work
Old Dec 7, 2005 | 10:44 PM
zumiez007's Avatar
Default Re: (cambopheonix56)
You've got two super simple options. 1.) You if you completely unbolt the air box and remove all of those pipes leading down into the bumper, and re-install everything without those lower pipes/resonator. 2.) remove the air box and everything below it and bolt in a cone filter to the intake pipe.
That is, if you don't want to purchase a short ram or cold air intake from ebay or whereever.
Old Dec 8, 2005 | 04:30 PM
i_kick_turtles's Avatar
Default Re: can i just put a cone filter on stock intake (90babyblue)
Here's a write-up:
http://www.cb7tuner.com/vbb/showthread.php?t=6532
Old Dec 8, 2005 | 04:59 PM
HandoEX's Avatar
Default Re: can i just put a cone filter on stock intake (I R Tylor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I R Tylor &raquo;</TD></TR><TR><TD CLASS="quote">Here's a write-up:
http://www.cb7tuner.com/vbb/showthread.php?t=6532</TD></TR></TABLE>
That's sweet I bet there is a lot less noise with similar gains compared to a piped sri
odiumred
Jun 22, 2007 11:27 AM
Iomega01
Aug 9, 2005 12:51 PM
dip-set
Mar 5, 2003 10:53 AM
2005 TSX
Mar 27, 2002 12:00 AM
