90 accord ignition question
Old Dec 7, 2005 | 04:11 PM
redspiritguy's Avatar
Default 90 accord ignition question
can anyone solve this one?
ive got a 90 accord A/T. When its cold out the ignition key will not come out of the switch. You can turn it back to the ACC position but not to OFF. If you fiddle with the steering column and jiggle the key and hold your tounge right eventually it will come out. Anyone??
Old Dec 7, 2005 | 05:50 PM
monzster's Avatar
when this happens see if you can take the key out if you push the gear selector into park further while turning it.
Old Dec 7, 2005 | 07:08 PM
Default Re: (monzster)
tried, but no difference
Old Dec 7, 2005 | 07:59 PM
PhantomPhanatic's Avatar
Default Re: 90 accord ignition question (spoonmectr)
Same year MT......Mine does the same thing...but the weather doesn't matter....every once-in-a-while it'll do it.....it's not really a problem for me....I got used to it...I wouldn't worry too much....it's just a minor inconvenience....
Old Dec 8, 2005 | 03:55 PM
Default Re: 90 accord ignition question (PhantomPhanatic)
its not minor for me though. takes at least 10 minutes to get my key out on the cold mornings.
Old Dec 9, 2005 | 01:50 PM
wastro's Avatar
About the car taking forever to go into park sometimes --- that happens to me, too. A mechanic told me it was the neutral safety switch. Just ordered a replacement from Napa and hope that it works (costs about $55).
Old Dec 9, 2005 | 01:54 PM
deserthonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonmectr &raquo;</TD></TR><TR><TD CLASS="quote">can anyone solve this one?
ive got a 90 accord A/T. When its cold out the ignition key will not come out of the switch. You can turn it back to the ACC position but not to OFF. If you fiddle with the steering column and jiggle the key and hold your tounge right eventually it will come out. Anyone??</TD></TR></TABLE>
have u tried a different key?? if u don't hjave 1 have the dealer cut u another key.........also get some wd-40 and spray it where the key goes in do not worry it will not damage anything
Old Dec 9, 2005 | 04:08 PM
Default Re: 90 accord ignition question (deserthonda)
if it was the key, then it would have problems turning the lock cylinder, yea ive cleaned out the lock cylinder and sprayed graphite.
singlecamsaint
Apr 14, 2011 07:36 PM
Rushesright
May 20, 2008 07:31 PM
jim lenfert
May 23, 2006 05:59 AM
JimKW
Sep 20, 2005 10:37 AM
swiftstyles
Jun 1, 2005 12:40 PM
