map sensor probs
the voltage between the red wire and a chasis ground is 5v but between the red and white wire on the harness it was reading .002 so i would seem that the ground between the plug and ECU is open but there is conduity between the ecu and the plug....
the real question is can i just ground the map sensor to a chasis ground or does it have to be grounded to the ecu for the ecu to read it properly... anybody have there maps wired like that?
Gant
May 18, 2005 08:47 PM
