FS: USDM h22a1 Engine+Head.... 133k ALSO FS: JG HEAD!! h22 NIB
http://cgi.ebay.com/ebaymotors...43211
Hey im selling my block. It was running poorly before, but after tearing the head off, I cannot diagnose the problem. There is very little carbon on the pistons, and there is NO scoring of the cylinder walls. The head is also in good condition, showing equal carbon on all valve faces , and there seems to be NO problems.
IT will come with
Oil pan
Lower end (pistons/rods/crank)
SEPARATED :
head
usdm cams
set of JDM cam and cam gears
Distributor
Intake manifold
Injectors
vacuum etc.
AND:
JG Head 0 miles since machine work (<10k before rebuild)
Port and Polished
Crower Titanium valvesprings and retainers
crower springs
All valves Just refaced
Just replaced all seals
Cam seal (oem)
JDM cams? (oem cam gears or adj cam gears +80$)
NEW PICS!<U></U>
(that is oil/lube on the head)
http://img404.imageshack.us/im...m.jpg
Modified by DarkBB4 at 5:55 PM 12/8/2005
Modified by DarkBB4 at 12:13 PM 12/12/2005
Modified by DarkBB4 at 12:14 PM 12/12/2005
Modified by DarkBB4 at 4:53 PM 1/10/2006
IT will come with
Oil pan
SEPARATED :
head
usdm cams
Distributor
Intake manifold
Injectors
vacuum etc.
AND:
Port and Polished
crower springs
Cam seal (oem)
NEW PICS!<U></U>
how much for the block only? I'm in jersey I prob could pick up if distance is reasonable. I'm collecting all parts for my turbo project and I need a block to have it build a sleeved for turbo, I have my block in my car in the car, but can't part it out since I drive it all the time.
