Buddy's car wont start.
Old Dec 7, 2005 | 11:51 AM
bleebdat's Avatar
Default Buddy's car wont start.
Hey all, my roomates 96 ex wont fire up right now, it doesnt seem to be getting spark at all, the fuse is intact, we replaced the rotor and cap since they both looked a little corroded, is there anything else it could be that we can check before biting the bullet and buying a dizzy?
Old Dec 7, 2005 | 11:55 AM
postman's Avatar
Default Re: Buddy's car wont start. (bleebdat)
first check for spark and fuel. pull out plug 1 at a time and keep it in plug wire place ground strap on plug to block and crank you should see spark jump the gap. no spark sheck your coil for power. to test fuel use pressure gauge
Old Dec 7, 2005 | 12:36 PM
bleebdat's Avatar
Default Re: Buddy's car wont start. (postman)
The car defineatly doesnt have spark, how can you test the coil? Im pretty sure it has fuel, I can smell the unburnt fuel after cranking it a few times.
Old Dec 7, 2005 | 04:49 PM
bleebdat's Avatar
ttt any help, he needs the help =P.
Old Dec 7, 2005 | 11:10 PM
postman's Avatar
not exactly sure off hand exact process but. locate coil ground and use voltmeter, test light, while cranking,
Old Dec 7, 2005 | 11:35 PM
Rev Hard9999's Avatar
Spark plugs
Old Dec 8, 2005 | 03:09 AM
dew80362's Avatar
You take the coil out and look at it. You can see if the coils toast by just looking at the casing. It'll be somewhat melted looking or distorted in an area if its burnt out. Don't forget to check your ignitor too. Check the wires running too it and make sure that they are all on there snug. Then test it. Not sure the exact Ohm reading for it but it also could be a factor. Most likely its just the coil though. GOOD LUCK!
civic2sick
Feb 26, 2020 09:39 PM
dj-t
Jan 27, 2011 05:55 PM
kondrams
Honda CR-V & Element
Dec 13, 2010 11:30 AM
Cameron60
Feb 19, 2009 10:22 PM
A2gt35r
Sep 30, 2007 06:26 PM
