mini me wont start yes i searched
ok heres the story........ i have a a6 block with a z6 head i hit a deer with my 89 hf and totaled it. i have 2 89 hfs so i took the engine and everything out of the totaled one and put it in my other hf. well i started it and it ran allright shut it off then started it again the check engine light came on and it was starting to flood out. so we looked at the totaled one's wiring harness on the pass. side back by the black box and hooked them up the same, hoping to make it stop flooding out. instead it made it not run. so we hooked the wires back up the way they were. now it wont even fire. we changed the dizzy, computer, (i have the pm6 and the vtec is not hooked up or workin) please help i need this car running!!!!!! i searched and came up with a few but none of them helped. HELP PLEASE
wat do you mean by "flood out"? its unlikely that a fuel injected car floods, unless something is causing the injectors to stay wide open, and your o2 sensor would trip out. look at your sparkplugs, see if they are wet
cybertek12
Mar 22, 2004 04:13 PM
