b16a2 idle problem what is this part called
Old Dec 7, 2005 | 11:32 AM
b16brandon's Avatar
Default b16a2 idle problem what is this part called
My civic has been idling erraticly. The thing in the picture has a broken hose connector, the part that leads to the canister in the picture. Is this the cause of my idle problems?
What is the name and fuction of the part circled in the upper left, and where does the vacuum line lead to. I see that it says canister, but what is that, and where is it. Pictures help very much. Thanks.
Old Dec 7, 2005 | 11:51 AM
postman's Avatar
Default Re: b16a2 idle problem what is this part called (b16brandon)
part circled is purge solenoid, for you charcoal CANISTER. part of evap system, actually helps save gas in long run
Old Dec 7, 2005 | 01:07 PM
red91sit's Avatar
I don't think this is the cause of your idle problem, mine's not connected, and it still works fine.
That part may also be referred to as an evaporative purge solenoid
Old Dec 7, 2005 | 01:22 PM
RACEPAK's Avatar
Default Re: b16a2 idle problem what is this part called (red91sit)
try the IACV....
crxguy406
Sep 10, 2015 03:56 AM
96hatchBoy
Mar 28, 2013 06:17 AM
longshot
Nov 30, 2008 10:44 AM
djviet2000
Aug 20, 2008 08:19 PM
