B16 EG Swap
Old Mar 14, 2002 | 06:49 PM
Edmund4th's Avatar
Default B16 EG Swap
I would like to know what is involved in swaping a 1st generation B16 (cable tranny or whatever) into a EG hatch. I know that the engine goes for like 1400 compete and there is a conversion kit for 200 to convert to hydrolic but how hard is it? and would you recomend it? Or should I jsut go with the Hydrolic B16 thanks alot.
Old Mar 14, 2002 | 07:08 PM
Plan B's Avatar
Default Re: B16 EG Swap (Edmund4th)
Well, i actually did this swap earlier tonight. You will also need the distributor, injectors, ECU, and some kind of axles(i don't know yet, still looking, think 90-93 integra, but they were too short.) It will cost you over 2000, and that's what you can get a hydro type for at JDMhondaparts.com Call sheng and bug the **** out of him, he loves that stuff.
Old Mar 14, 2002 | 07:22 PM
Edmund4th's Avatar
Default Re: B16 EG Swap (Plan B)
Yeah, I am now thinking about just getting the hydro engine, and that will go in with no trouble correct? Like a complete swap is bolt in right? Thanks. If you want to talk over AIM my screen name is Edmund4th.
Old Mar 14, 2002 | 07:29 PM
Plan B's Avatar
Yeah, the SIR II hydro b16 was made for your car, it would be so easy to put in.
Old Mar 14, 2002 | 07:30 PM
DragII's Avatar
25 Year Member
Word.
I'll co sign that.
Old Mar 14, 2002 | 07:47 PM
Edmund4th's Avatar
Default Re: B16 EG Swap (EvilDragII)
Sweet, thanks alot, now if I just hat the money for all of this. Oh yeah, and what is the best price I can get on the B16A2 and where can I get it. And Evil Drag, I know that white thing is not in your garage. Or is it?
[Modified by Edmund4th, 4:49 AM 3/15/2002]
Old Mar 14, 2002 | 08:48 PM
Eg6_JDM's Avatar
go with a b16a 2nd gen.......i spent about 2500 for parts and motor on the first gen.....
i got jib ova 2nd for a 1st......but still took the motor.....bad choice
[Modified by Eg6_JDM, 5:49 AM 3/15/2002]
Old Mar 14, 2002 | 09:04 PM
Edmund4th's Avatar
Default Re: B16 EG Swap (Eg6_JDM)
Alright, thanks for the input. What else would you recomend I should purchase with the install? Clutch, urathane motor mounts, Hwat else? THakns again.
Old Mar 14, 2002 | 09:07 PM
DragII's Avatar
25 Year Member
I changed the timing belt, water pump, and clutch....easier to do while the motor is out of the car.
707the89fu
Mar 1, 2007 09:28 AM
KarbinFourteen
Sep 25, 2004 06:04 PM
civictyper96
15
Sep 13, 2004 11:24 AM
clintwsi
May 8, 2004 10:34 AM
team213
Apr 4, 2004 03:18 AM
