bushing press... or manually press needed?
Old Dec 7, 2005 | 09:01 AM
idriveadelsol7's Avatar
Default bushing press... or manually press needed?
can you just manually push in the shifter bushings... or do i need to take it to a shop to get it pressed in? something like this:
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Dec 7, 2005 | 09:05 AM
93CivicSI's Avatar
Default Re: bushing press... or manually press needed? (idriveadelsol7)
You will not need a press for the shifter assembly.
HOWEVER - if you decide to change your suspension busings, you will need something like this:
http://www.harborfreight.com/c...=1667
Old Dec 7, 2005 | 09:12 AM
Default Re: bushing press... or manually press needed? (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI &raquo;</TD></TR><TR><TD CLASS="quote">You will not need a press for the shifter assembly.
http://www.harborfreight.com/c...=1667</TD></TR></TABLE>
this is regards to all shifter bushings in that set right... i believe there are only 2 of them. 1 where the shifter is, and 1 where the shifter meats the transmission bracket.
harbor friehgt
Old Dec 7, 2005 | 09:15 AM
teal_dx's Avatar
I installed an Energy Suspension Master kit without a press, I used a bench vise to push them in, and a blow torch to burn them out. the oem bushings were pretty rotted to begin with. Just grease them up, line them up with the arm in the vise grip, and tighten slowly. if it starts to go in crooked, use a flathead screwdriver to push the one side in more. I had a couple pop out while I was tightening and ahoot across the garage lol
Old Dec 7, 2005 | 09:20 AM
Default Re: bushing press... or manually press needed? (teal_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx &raquo;</TD></TR><TR><TD CLASS="quote">I installed an Energy Suspension Master kit without a press, I used a bench vise to push them in, and a blow torch to burn them out. the oem bushings were pretty rotted to begin with. Just grease them up, line them up with the arm in the vise grip, and tighten slowly. if it starts to go in crooked, use a flathead screwdriver to push the one side in more. I had a couple pop out while I was tightening and ahoot across the garage lol</TD></TR></TABLE>
i have hardly any cool tools... and i don't wanna take out my bitch pin to get the thing in there... any other methods?
Old Dec 7, 2005 | 09:23 AM
jbs's Avatar
jbs
No. ES bushing that goes to the tranny side comes in two pieces. I notice the pictured brand is Prothane but I believe they are all the same.
Old Dec 7, 2005 | 09:29 AM
Default Re: bushing press... or manually press needed? (jbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs &raquo;</TD></TR><TR><TD CLASS="quote">No. ES bushing that goes to the tranny side comes in two pieces. I notice the pictured brand is Prothane but I believe they are all the same.</TD></TR></TABLE>
that's what i was thinking. if they come in 2 pieces, i can manually do it. but form that picture, it looks like a solid 1 piece.
x_tuh_sy
Dec 8, 2007 12:03 PM
clubef9
19
Apr 13, 2007 04:44 PM
THE94GSR
Feb 2, 2004 06:50 AM
Mugen Hamster
Dec 19, 2003 11:33 PM
Redlined-EH3
Dec 5, 2003 10:44 PM
