transmission cooler?
Old Dec 6, 2005 | 10:21 PM
eg686's Avatar
Default transmission cooler?
I know Accord transmissions are weak, automatic that is. There is such thing as transmission coolers right? They cool the tranny so they can last longer. I believe I read about this in another forum. It talked about how to take care of your transimission. They said just buy a transmission cooler and don't drive hard and it will last longer? Anyone want to chime in?
Old Dec 6, 2005 | 10:57 PM
BLKFLSH's Avatar
Default Re: transmission cooler? (dchan86)
They say, add a cooler if you plan on doing any towing or adding power to the engine (running it hard). Of course you could do that, and it craps out on you anyway. I say unless you will be towing, or adding power, you should change the fluid more often, say every 15k or 30k miles which is what I plan on doing (30k), instead of 60k, like my maintenance schedule says for severe conditions.
Old Dec 6, 2005 | 11:21 PM
YeuEmMaiMai's Avatar
The only "weak" tranny is V6 accord transmissions. the 6gen and older cars I4 trannys hold up very well. I change my fluid once a year regardless of milage (I drive about 11K / year)
For best performance it should go in front of your a/c condensor but if you own a 5th gen this isn't the best place to put it since the A/C is weak in the 94/5 cars. Next best place is between a/C and rad.
Old Dec 7, 2005 | 12:06 AM
P_Adams's Avatar
Honda already incorporates a cooler in the Radiator for the Trans cooler; but adding a second in the system is still a viable alternative.
P
Old Dec 7, 2005 | 02:01 AM
The_Todd's Avatar
Farts in the shower
Well you don't want to cool the tranny fluid too much because, like oil, it needs to be at a certain temperature in order to properly lubricate. People often think that they need to add a AT cooler but fact is, unless you're doing some major towing or very hard driving it simply isn't needed...save your money IMHO.
Old Dec 7, 2005 | 07:03 PM
f23ra's Avatar
Yes get one before it is too late! also don't forget to change tranny fluid every 15,000 miles or once a year. that's why most automatics don't last that long. I got stuck in the mountains one time whith my 99 accord. that's the Only time my car has left me broken down on the side of the road..so far since i bough it. I let the maintenance go too long on the tranny. it heated up & slipped. the oil looked like melted chocolate.(it's suppossed to be red). the oil cooler will definetly help in extending the life of your transmission just dont forget fluid changes
HondaAficionado
Transmission & Drivetrain
Jun 11, 2009 12:14 AM
Baron55
16
Feb 23, 2008 02:06 PM
chakup
Jul 6, 2006 05:07 PM
klaner
May 1, 2003 01:04 PM
