New redline with crower springs and retainers?
okay...along with my new turbo setup...i'm doing up my valvetrain...i've decided to go with Ferrea valves and Crower springs and titanium retainers...
question is...how high can i take the redline safely?
with crower you can do 9,000 with no worries... question is will you be making power that high ?? so choose your route wisely
well my block is fully built...using Pauter rods...stress still an issue?
i'm using a 7AL-2 with a soft touch rev limiter...so i have the option to raise it or lower it....reason i want to rev higher is that i don't want to end the 1/4 in 5th gear
?also how much PSI you planning on boosting.
[Modified by BlueShadow, 11:08 AM 3/16/2002]
okay let's assume that the power curve keeps going up...where should i call it quits?
You still have to deal with a bottle neck, the cylinder head and the camshafts. being able to rev to 9000-10000 RPM wont mean anything if you cant flow more air into the engine. Which is I guess where the Turbo comes into play, But I wonder how much you would benifit from a P&P...
Spo0NFed E M 1
20
Jul 13, 2006 02:56 AM
