Suspension & Brakes Theory, alignment, spring rates....
Swaybars on a EK?
Old Dec 6, 2005 | 08:33 PM
96Spec Ek's Avatar
Default Swaybars on a EK?
I'm looking through a bunch of different sets of swaybars and would like to know what everyone else is using and your feedback on them. I already have the 99 spec Apexi N1 coilovers w/ pillow ball mounts. Im liking the price on the Suspension Technique kit but Im iffy about the quality. I also have seen and love the comptech rear but have not seen a front kit. Id like to stay with the same company so lets hear it, whats out there?
Old Dec 6, 2005 | 08:42 PM
vietnameeh's Avatar
i have the STs...worth it for the money ... at least i think
Old Dec 6, 2005 | 08:43 PM
SuperSlow's Avatar
Default Re: Swaybars on a EK? (96Spec Ek)
comptech or asr w/ 23mm itr... but if you are just driving around on public streets, get the si bar and call it a day...
Old Dec 6, 2005 | 09:22 PM
96Spec Ek's Avatar
Default Re: Swaybars on a EK? (SuperSlow)
Ive seen a good write up on the asr bracket and itr swaybar with some nice endlinks. What about the front though?
Old Dec 6, 2005 | 10:32 PM
EK k kay's Avatar
Go with a stock Si front bar with the matching LCA's and shock forks.
Old Dec 6, 2005 | 10:40 PM
96Spec Ek's Avatar
Default Re: Swaybars on a EK? (EK k kay)
Ok the front is getting done first then. I'll make a run to Honda and order those parts cause I know they will be on back order. Are there any aftermarket endlinks for the front bar? Why do I need the si front shock forks?
Old Dec 7, 2005 | 12:46 PM
spoonek9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Spec Ek &raquo;</TD></TR><TR><TD CLASS="quote">Why do I need the si front shock forks?</TD></TR></TABLE>
The Si front LCA is wider. You will also need a longer bolt to go through the fork.
Old Dec 8, 2005 | 07:43 PM
alwaysoverkill's Avatar
i'm using my stock 23mm front with a 22mm CTR rear using a Beaks kit for now, I love the 22mm rear sway bar. Makes the car turn-in so much better, night and day difference on sharp corners, no difference on long corners or around town.
I just went OEM Honda, its cheap and obviously great quality, I'm going to go with ASR soon though, so i'd recommend that over Beaks, EK is thin subframe
Old Dec 8, 2005 | 08:49 PM
deviant1's Avatar
Default Re: (alwaysoverkill)
Get that ASR soon. I was using the beaks kit and when i took it off to put on my ASR brace, the edges of the holes on the subframe were pulling up.
Old Dec 9, 2005 | 06:44 AM
Slosc2's Avatar
Default Re: (deviant1)
Bigger is better with swaybars right???
I run a SI rear and EX front bar on my hatch. Youd be surprised at how drastic the change is just by adding anything.
I started with a GSR rear bar only, wanted more, than stepped to a EX front bar. Wanted more again, and am Really happy with the SI rear and EX front bars. All factory equipment, and what i paid for the setup is just awesome. I have roughly $100 in both swaybars, mounts, Front LCA's and all the necessary hardware.
Old Dec 9, 2005 | 12:10 PM
nonsense's Avatar
I run a rear 22mm ITR bar and no front bar on my 99 DX coupe. I've never had it oversteer when I didn't want it to.
intevic_dx
Suspension & Brakes
Apr 19, 2006 07:13 PM
Solscud007
Oct 28, 2004 08:55 PM
x00gsr
May 20, 2003 09:52 PM
SW20 MR2
Aug 20, 2002 07:39 AM
Halo
Jan 2, 2002 12:38 PM
