fuel injector question
ive done the search thing. mostly i get found 0 results, or everything i find is for b18's. Im rebuilding my odb0 b16a1 with ctr pistons. should i switch to a bigger injector to compensate for compression? if so, what cc injectors should i go after? what cc are my stock injectors? is there a stock injector from another b series motor i can use? thanks in advance.
98integrars
May 7, 2013 10:04 AM
