1050CC Injector clinic injector question, help??
I have a set of 1050cc injectors from injector clinic. Part # IS115-1050... here's the description of them..
Fuel Injector Clinic Description: Honda Acura B,D,H & F series Injectors [set of 4]
With OBD1 injector plug
Peak and Hold/ Low Impedance Ball & Seat Injectors
Now my question, I'm looking at installing onto a full built GSR motor for my turbo build, can they be used with the stock fuel rail? I tried putting them on today to replace the 440s I have and them seemed to not fit right? Anyone used these or know anything about them? Seems like if you remove the rubber seals on the bottom/top they could slid in but I doubt there supposed to be ran without those seals.
Picture of them taken from google.
https://www.jdmpartswholesale.com/pr...-civic-b16-d16
Anyone?
Anyone?
Re: 1050CC Injector clinic injector question, help??
These injectors are made to be a stock replacement and should be fine to fit with the stock fuel rail. Can you describe your fitment concern more specifically? They should fit properly with all of the seals that they come with.
If you need, feel free to post a photo.
