does arp make head studs for the d15b7?
are there performance head studs for a d15b7? or do i need to do a mini me swap and use the d16z6 head studs? i know the d15 sucks...im building a d16, and want to see the max boost the d15 can take...but i know the head gasket will blow anything over 10 psi...so i need the head studs. thanks for your help.
jeez, that was fast. i have never seen studs for the d15...is there a site that you know of that has them? and you know FOR SURE that d16z head studs will work for the d15?
thanks alot
thanks alot
